Single Turbo Skylines
It is easier and cheaper to get big boost happening with a single turbo. The main advantage of the two turbos is for better response low-down. If you're not concerned with this then there isn't much point having 2 turbos.
Of course, the twin turbo setup on the GTR is better than the single turbo on the GTS-t. But the GTR owners doing the single turbo conversion are usually bolting on one bigass $10k+ Trust turbo or the like, not a small turbo off a GTS-t :D
I dont know about the lag difference between using 2 smaller turbos and a larger single. From what people have said and tried, is that the single can be equally laggy if not better than the twins due to all of the exhaust going into the one turbo to hel pspool it up and not being halved to run two of them. Hope that makes sense, Im very tired!!!!
When I decided to do a complete rebuild of my engine, I decided to go a large single setup instead of a medium twin setup like a 2835 or 3037S for a number of reasons.
Primarily, price. With a TT setup, you have almost double the costs in dump pipes, wastegates and the like.
A single setup only requires one dump pipe and one wastegate.
Also the large single turbo is less laggy than the above mentioned twin setups. My turbo will spool at about 4300 and keep climbing past 8800. My rev limiter is currently set to 9000rpm in an effort to make the engine last as long as possible. The turbo itself is good for 35psi which would create as much as 500rwkw at the wheels in a GTR with the correct setup engine.
A twin setup such as the 2835s or 3037s setup won't spool till after 5000rpm unless you do a larger bottom end like Munro.
What about rigging up a sequential turbo setup to a GTR? Is that common, or too much effort? Wouldn't that overcome the problem of lag and give the best response over the whole range?
I'm talking about mainly Japan, because i know there aren't too many GTR's out here comparitively, probably even less modified.
I think sequential turbos are largely a waste of time for a performance car. They only really improve driveability. They also lower your off-boost threshold so you'll probably find that you're always going through more fuel.
To overcome the disadvantage of not having a sequential turbo setup, launch from a higher RPM and keep the revs up.
Originally posted by brendanf
hoe lee fark that is a nice engine !!!!
Are you sure you couldn't have fitted a bigger turbo to that ???
Appreciate the comments all.
Yes I could have gone a bigger turb than that but this one suits my hp requirements at the mo :D The only thing is that if I do go bigger now, I need a new manifold which positions the turb further forward. I do know of a car running the larger turbo and it's making 460rwkw on PULP on a base mapping :eek:
The turbo itself isn't actually a T88 but a Garrett equivalant which was custom sized wheel and exhaust housing to suit my requirements of a faster spooling turbo. The exhaust housing is the size of a T78.
where can i get an intake pipe like the one on there?
Call Unifilter and they can sort you out. That's a 5" pipe they usually fit to trucks.
Dude,
Obviously you weren't looking close enough to the 2 cars :P
Ben's turbo is BIGGER for one, his intake piping goes down through the chassis to the bottom where the indicators are on a stock front bar, and most importantly, his car is white!!
His rocker covers are black (used to be red), and his radiator shield is a stainless silver piece.
His intake plenum ain't stock. His catch can looks different. He runs Tomei cam gears.....
Should I go on???
:shake: :shake: :shake: :shake:
Originally posted by INASNT
dave isent that engine pic of one of bens cars from race pace??
i have seen that engine bay in the flesh and your car in the flesh and things dont add up :confused:
:shake:
Guest INASNT
Originally posted by Leewah
Dude,
Should I go on???
:shake:
hehehehehe, smart ass!!
i always thought u had twin low mount turbos on yours?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
