i ran my car about two weeks ago, so far only mods i have done is motor rebuilt at 125k with je pistons...... turbo out of series two which has been converted from ceramic to steel.....hks box air filter....jasma twin loop exhaust.....GFB stealth fx bov..... my quickest time was a 13.89 @ 106 mph
My GTT R34 ran 13.76 @ 161km/hr with 2.14 60 foot time.
ONLY MODS ARE:
- 10.8 psi boost
- Cat Back Exhaust with a metal cat
Even have time slip for it
Oh sweet man nice one..
i got a R34 gtt just with a cat back exhust, pod fitter with 178kws at the wheels
yeah? thats a real good power output, i have just dynoed mine as well 3 days ago and got:
- Stock boost: 175kwrw
- 11 psi: 184kwrw
Dyno @ Unique Auto Sports
Nice one Anna as per phone call :)
the black beauty is back with a vengence :)
was good to see it out there tonight
fanks guys... only went to see the new gtr run.......... oh wells... 7 runs in before 9.30..can't complain :O
p.s Dave was driving.... at least if the engine sounded a lil off he would of noticed... I hope!
p.p.s discovered with the oil on full mark it still had mild oil surge mid track..... need baffles, or an extra litre of oil ...lol
r32 gts-t stock 14.234 qtr 1.989 60ft 99mph best run last wensday
for a stock s**t she goes hard .. :whistling:
http://www.badgerphotography.com.au/SM%200...s/120907172.htm
http://www.badgerphotography.com.au/SM%200...s/120907174.htm
youtube vid up soon nothin special but felt like a great launch and looks good from a stockie :P .
also what are the good times from stock r32 gts-t ?? mate did a 12.8 in a r33 gts-t with 270+ kw so for a 160kw stock gts-t it felt good
will post up time sheets and dyno chart soon:D:D:D:D
Mate, no offence but its real hard to believe your R32 GTS-T is stock if you made 14.234 unless if you have good tyres or some mods. Also another thing is R32 GTS-T stock is not supposed to be 160kwrw ( i know every car is different but 160 is too high mate), that power is wat R34 GTT stock pulls.
he is talking in engine kilowatts
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
