  • 1 month later...
12.5 @ 115mph on M/T WSID Wednesday night R33 GTS Skyline 9-3-2011
Skyline R33 9-3-2011 @ WSID Wednesday night Burnout after running 12.5 @115mph
tyres on the back are off a R34 GTT 235/45/17 they were like new untill then
Edited by madr33
  • 1 month later...
  • 5 weeks later...
I ran this time ages ago, 24/9/2011
Stagea 260RS
60': 1.929
ET: 12.34
Kph: 181.64
Did this in full street trim, on 19's with streached rubber, a full tank of fuel and jack/tools/spare.
Managed to get some pretty epic wheel spin the first few runs and i'm keen to see what i can get with 18's, better rubber and a lower 60' time
  • 6 months later...
R33 GTSt 25/30 380ish Killerwasps
60ft 2.150
330 5.698
1/8 8.260
mph 99.77
1000 10.403
1/4 12.147
mph 130.38
Hankooks RS3
Good top end but I cannot seem to get off the line well due to wheel spin.
  • 3 weeks later...
  • 8 months later...
32 gtr with old Nexens, N1 turbos, exhaust, pods, 1530kgs, plus me:
60ft- 1.78
1/8- 7.72
1/4- 12.075
Mph- 112
Was hoping to go about 12.2, so was stoked!!
Nice work! I think I saw one of your runs.
32 GTRs still the best looking car out there! :)
R32 GTR
i ran 11.8 twice on the stock turbos & stock ecu
16psi
Evc 6
turboback exhaust.
Ku31's
234rwkw ( unigroup dyno )
1.7 60ft @ 116 mph.
lil video in my page http://www.youtube.com/user/sultanaz69/videos
time slip in the description of the video
i suggest if you watch it turn down the volume after i drag because i get a phone call and i get a lil excited.
Cheers
Edited by sultanaz
R32 GTR
16psi
Evc 6
turboback exhaust.
Ku31's
1.7 60ft @ 116 mph.
Cheers
Good run mate, congrats!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
