Hi everyone, I got this GTR 2 weeks ago and this is the first time i've had a camera so i took some photos. Don't mind the dust (GRRRR black cars)
Its a Vspec with Brembo brakes. Apart from that, everything is stock, even the exhaust! Got some 17" light weight enkei rims though.
What do you think?
https://www.sau.com.au/forums/topic/111320-my-new-gtr-with-lots-of-pics/
wow .... nearly ran out to check if mine was still there until i saw the pee shooter exhaust :fakenopic:...... thats a good sign the small exhaust that the cars fairly fresh i think ........well done !
Welcome to the black gtr club :starwars:
Now buy a good shammy .....
wow .... nearly ran out to check if mine was still there until i saw the pee shooter exhaust :P...... thats a good sign the small exhaust that the cars fairly fresh i think ........well done !
Welcome to the black gtr club ;)
HAHA, does your car have the same wheels too?
Your right about the condition, stock cars are much fresher. Havn't had a compresion test yet but i don't think i need one, the engine feels strong and is very smooth. Engine bay looks very tidy, the interior is fairly nice for a 13 year old (the dash has a few bubles) and the body is excellent.
Toke it around yarra blv today. OMG, it just pulls & pulls and the car is just so solid on the bends.
The stock setup is pretty good, very communicative. Going into a corner with hard braking will push the tail out & go hard on the gas, little opposite lock and the 4WD just pulls the car straight.
I don't know why people complain about the 4wd lag, its very quick to respond. I was told that the Vspecs had the 33 computer in it so that might be the reason.
Can't wait to go for a cruise to the G.O.B :rofl:
MY GOD, BLACK R32GTR and its a V-SPEC as well???? I want I want. Nice and clean car there dude, i've got a black one as well.
We should organise a cruise with 32GTR's only, sound good?
HAHA only Black 32GTR Vspec Cruise, don't think there will be many around mate. Only joking
yeah, GTR cruise sounds awsome, love to take some shots of 10 or so clean 32 GTRs together!
Beautiful GTR – have always loved the black (& Bayside Blue) & know the problems with ‘clean’ black!! Speaking of which, what are recommendations for polish/cut/crème/wash, for being quick and easy, as much as I love touching my car, I don’t want to spend all weekend washing it!!
I’ve used some ‘Mothers’ stuff, but think that ‘McGuires’ is better& had some horror experiences with Turtle (your know their farked when there on their back!). What’s your experience?
Love black – hate the effort!
I compromised for metallic silver – not as sinister as black, not as angelic as white!
:rolleyes:
:P
Hi mate,
McGuries is ok but i use AUTOGLYM. Just use McGuries wet look to wash the car, then use AUTOGLYM wax & polish. I find it gives a much better result. I wouldn't be using paint restore unless the paint looks a bit dull.
This GTR has a gold/bronze peral though it when it is in the sun light. Looks awsome.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
