hay guys,
i actually found this after i installed mine... and i had no trouble with hoses and so on... didnt have to replace any of my standard ones, any way it works really well and the car makes 487awhp . so im happy..,. i got all my pump and equipment from efi hardware so if u have any needs ring them..
  • 2 years later...
  • 2 months later...
  • 8 months later...
do you need to get covers for the wires connecting to the fuel pump? No one has mentioned it and my old 31 had exposed wiring, i just don't know if it's safe seeing as it's in fuel? That said it shouldn't spark if all connected properly anyway?
  • 1 year later...
Quick question installing 044 pump today is the factory lil reg looking thing a one way valve or do I need to fit an aftermarket one that attaches to fittings ???
I think that is just some form of dampner from memory... There was one on my 34GTR pump when i removed it but not on the 044 when it went back in!
should put a valve on it, speed flow should have the fittings and valve to suit
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
