  • Replies 224
would you happen to still have the gauge cluster and ummm there's this black square thing on top of the valve cluster. some wires plug into it. i know im not being specific, but hopefully you know what im talking about.
JETGTS, I'm after the drivers side window winder motor. Do you still have it, and how much do you want to for it?
Also the drivers side button door panel would be good if it's still available. :P
hi you going JETGTS do you have:
* Plastic Dash
* Oxygen Sensor
* Skyline Thing at back says (Skyline)
* Right Side Taillight
Im in melbourne ill come and pick em up in the weekend if you have any
cheers
AK
Streamer - I have just the left shock and I am not separating the turbo and manifold sorry
Peter Behrens - Entire body shell i.e. stripped right down? The chassis front right is lifted 20cm higher than it should be and the firewall is slightly buckled on the right. Everything else is like new
Sciby - the drivers side window motor u r looking at 150, let me know what u think. I'm selling the door interior as one bit sorry.
hehehehe - boost solenoid $20? i don't really know what they're worth - always welcome to come have a look at what i've got though, and i'll try and find the solenoid 4u
naveed - plastic strip the battery is behind? i'm not sure what u mean but I know I haven't sold it! I have it if u can explain a bit better?
WLD747 - I have all of these parts. give me a call whenever and we can discuss
hippy - I have the rear bumper support. Let me know when u want and do u want it sent to SA?
Any questions or if u guys are in a rush just call me 0401 598 511
or direct email [email protected] - cheers Ben
Guest
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
