Hey guys,
A friend of mine that works at ford can get me some front and rear brembo calipers, pads and discs from the BA series for a fairly decent price.
I would be looking to install them on my r33gts-t
What would be involved in fitting these if they fit at all?.
.......also a rough estimate on what someone would charge to fit them?
Can the discs be used ??
im fairly new to brake upgrade's so any info would be great....cheers
https://www.sau.com.au/forums/topic/111717-ford-brembos-on-r33-gts-t/
rotors are 355mm x 32mm cross drilled and slotted front rotors with Brembo 4 piston calipers ( 328mm x 26mm cross drilled rear rotors with red single piston caliprers, id think only the fronts on the 33 would need top be upgraded).
dont know the spacing of the calipers.... any 1 know their fords well?
look like radial mount calipers for the front.
will have to get an L shaped bracket made up (similar to the brackets in the AP kit below)
Add a 2 piece rotor (because the offset of the stock ford rotor will probably not fit on the GTSt) + custom hat...
it's not the cheapest upgrade.
something like the big rotor upgrades on UAS might be more economical... depends what you're after.
by what i can see on the DBA website, the stock Ford rotor is offset is similar to Nissan, but you can't be sure until you try it.
The beauty of custom brackets is that you can space the caliper 'offset' as you like to fit the rotors...
i looked into this once. calipers can be made to fit if, as Ronin said, you get the right brackets made. brembo will not sell you the bracket alone (bugger!). there is not much difference in offset apparently between the skyline disc (GTR anyway) and the falcoon one. but you'll need to make sure the hub locator is the same diameter and the stud pattern is redrilled because i don't think it's the same. and for the improvement in braking you're likely to experience unless you're going on the track, it's a lot of stuffing around. and that's before you even consider the rears and the changes to the handbrake assembly etc.
that's why the brembo upgrade is easiest/popular. unless of course you are Ronin and have APs :D . they are nothing but trouble :rolleyes: - you need to sell them to me :(
i think there are better upgrades you can do the braking system before chaning rotors and calipers. you wont be maxing out the stock calipers and rotors thats for sure. things like braided lines, slotted rotors, good fluid, good pads and even just a brake system service would make it heaps better.
i dont see a need to change em?
The handbrake set up in the rear is different and the brembo rear calipers should be a 4 piston caliperIf it is on anFPV or GTP as far as i know there wasn't/isn't a single piston rear brembo kit on them.Can you tell us all what is a good price or pm me with it as i may beinterested for a mates ba.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
