Hey guys,
Im looking at setting up a custom turbo on a NA engine and Ive been looking at some cheaper alternatives to bring the costs down.
As the $22 boost controller thread shows, there are options that are just as good as the name brand $$$ parts :D
Has anyone had any +/- experiences with:
cheap HKS "style" BOVs
cheap Tial "style" wastgates
no name intercooler cores
no name oil catch cans
anything else?
Share the love people :P:sleep::happy:
https://www.sau.com.au/forums/topic/111891-the-cheaper-alternatives-that-work/
thats no exactly rb only advice
most of the standard bov's are fine
the aftermarket ones generally cause more problems than they are worth. the oem cores are probably better than the jap ones. the catch is a bandaid fix on another problem, fix whats making the oil get into the intake.
its an N/A engine paul..and its not an RB, so we're not talking skyline....so from the info he's given (which is little to none) we dont know that there is a turbo variant to his car....therefore there might not be a "standard" bov....
what car is it dademon?
Intercooler: Get one of those Chinese Hybrid copies (they come from same factory as genuine Hybrid apparently). This can be had for as little as a couple of hundred bucks for the core and endtanks.
Oil Catch Can: You can use a coke bottle if you like, it will do the same job.
BOV: You don't need one straight away provided you don't run the boost too high.
Wastegate: I wouldn't skip on quality here, as your engine and turbo health rely on the wastegate functioning correctly.
Hey guys,
As the $22 boost controller thread shows, there are options that are just as good as the name brand $$$ parts :)
anything else?
Share the love people :P:P:sleep:
I've got a Chinacopy Fmic 300x600x76, not problems :)
-Cheap Chinacopy Westgate i would stay away, as i heard they have problems with holding boost, opening up at the right time and are just general a bad made item
-Same thing about the Bov, i heard they are just crap. seeing as you can get a secondhand jap spec (hks/blitz etc) bov for around $150-$250 i see no point getting a copy :)
-No name oil catch cans are fine, there is no real difference between a cusco one and they dont have any moving parts, so its ok
hope that helps :)
Cheers Michael :)
ps paulr33, if you can read the topic you would have notice, that they were asking "Has anyone had any +/- experiences with", if you cant answer the question dont post
Its actually a LS1 (5.7L Commodore). There's no point in getting opinions off the other V8 guys, I figure the SAU guys are the ones with actual hands on turbo knowledge :)
Im looking to turbo it which quite a few people are doing now but I dont fancy laying down the $10,000 for the "popular" kit.
The off-the-shelf kits are basically a GT35/40R, intercooler and pipes, BOV, wastegate and exhaust manifolds.
So, I want to run low boost (less than 12psi) single turbo. Ive talked to a few people that say a T04Z with a 1.32 housing is probably the way to go, but I dont know which other parts are capable of supporting this without blowing a bulk of $$$ on name brand parts.
Any help, no matter how small, would be really appreciated guys :thumbsup:
Dynomotive in Bayswater VIC have had a lot of success with turbocharging the LS1. They were the first to run a nine with A ls1 in oz so I dare say they have some research up there belt. They also had a LOT to do with the APS twin kit available.
In regards to not having to use a name brand part I have seen a few turbocharged LS1s come out there shop with the generic Bosch type BOV(s) and not have troubles.
I have an RB20det with 280+rwkw and I use a $40 bosch BOV without serious issue. Remember that a lot of BOV leaking issues is because they are plumbed in on the hot side of a restrictive cooler.
If you have a look at http://www.ls1turbo.com.au/ they are using KKR turbo, which are cheap as....(~$900)
If you look at this picture of one of their kits:
there isn't a whole lot to them. KKR turbo, exhaust manifold (surely any decent exhaust shop could do this for under $1000), intercooler ($200 + ~$400 for piping, silicone and clamps), wastegate and some lines (~$500), add another $500 for unexpected bits and pieces and do the install yourself.
I'm not sure what they charge for their kits, but I would bet it's a lot more than the sum of the parts involved....
Try $8,900 :D
Edited by dadem0n
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
