I don't agree with you saying that it's easy to make a slow car go quick and harder to make a fast car go fast. I understand what your trying to get across about reaching the limits of the car,.
Yeh so you know what im trying to say and it in no way was meant to take away from your time...:worship:
And yeh Sandown is a drag strip... you try driving my car and keeping up with any of you guys punching out 250+rwkws ...i know your pain all too well...you have to really concentrate on braking and corner speed.
I suppose my point was in light of other ppl doing great lap times i fear they may have been selling Jacks achievement short. It was his first day at Sandown, and thinking back its about 3 seconds quicker then a number of similarily modified GTRs on their first few outings...thats all.
....and anyway, since when did you ever read or listen to a single thing i have to say:)
  • Replies 126
Matt - Thanks man, your car looked awesome out there, from behind at least! :P Trying to keep up with you and Ray may be bad for my health... for now... :mad:
Jack - I'm hoping to get another second out of it with the same power, and I think I might have been able to do it if I hadn't have grabbed 5th instead of 3rd on every lap in my last session... woops haha
Everyone should be really happy with their times, and it was great to see everyones cars hold up, and no major incidents.
Thanks for the support everyone, made me feel really comfortable on my first track day, especially since I was a bees dlck away from losing my lunch before the first practice session! Was a really great experience, I've never had so much fun in my life than being out there, can't wait till the next one!
oh, and Ray, what kind of rear wing is on your car??
I agree mate. We all have to keep in mind that these days are meant to be fun and we shouldn't put pressure on people to punch out times. Sandown is a track that has claimed many Skylines, and i'm glad we didn't see that this time around. I must admit I feel more pressure at sandown, as people seem to use this as a benchmark and all the big cars come out to play.
I don't agree with you saying that it's easy to make a slow car go quick and harder to make a fast car go fast. I understand what your trying to get across about reaching the limits of the car, but at a track like sandown there is a lot of straight bits, and all these guys are pulling away from me fairly convincingly on the straight. At the risk of sounding stuck up, I had to work mega hard on my braking and corner speed to get a comparable time. I think without the oil on the track in the afternoon a 1.21.9 is possable.
You wanna try it on standard suspension.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
