These pods are now for sale - see HERE for anyone interested in purchasing them. I have many other gauge pods available now too - 180SX, S14, S15, Stagea, Forester, WRX...
I thought I'd post a few pics of of my latest project for my R33 for those who are interested.
My mate who has a WRX showed me a few pics of a gauge pod (made by AVO) that you can get for WRX/Liberty/Forester and sits at the bottom of the A Pillar. It's a nice alternative using a Greddy/Autometer style pod and drilling holes into you pillar and certainly more subtle that the A-Pillar pods. I looked around and sure enough, I couldnt find anyone who sells them for Skylines. The WRX ones are like $90 anyway.
So I thought i'd make my own, using Plaster of Paris as a template, make a reverse mould also out of Plaster of Paris and then fibreglass into that mould. For those who are interested, here area couple of pics so far.
All I did was mixed up a batch of approx 2L of Plaster of Paris, waited until it started to set (into a pretty gluggy consistency), poured it into a plastic bag and shoved it into the corner of the dash/windscreen/A-Pillar (see first pic). Once set, I pulled the plastic off and started shaping to roughly what I wanted with a file and rasp (see 2nd pic). There were a few holes and bits I had to mix more plaster to patch up, but it took about 3-4 hours to shape and sand it, minus the time it took for the patches to dry.
The last couple of pics are progress so far. What do you guys think? Total finished cost of Plaster of Paris and fibreglass should be about $40
Edited by MearCat
https://www.sau.com.au/forums/topic/112024-custom-corner-gauge-pod-project/
Mate that’s what I like to see, some creativity!!! I have been searching for a similar pod to fit a boost gauge in my S2 R33 but cant find one... those pillar pods arn't too bad but are a definite defect in NSW... please keep me posted with pics on how it turns out! Maybe you could be a buddy by making 2 of your prototype pod and seeing how it looks in my car :D hehehe... looking good so far! keep up the great work...
Regards,
Sarkis
I got the two halfs of the mould done last night. I should get to do some fibreglassing into these moulds in the next few days. Once set, the 2 halfs will then be glassed together and then automotive bog used to patch up any small inconsistencies.
The 2nd pic shows a pencil marking where the outer rim of the gauge (it's a 60mm Apexi EL2 boost gauge btw) will be situated.
When working with plaster of paris, white dust and marks get EVERYWHERE in your car. Once dry, the plaster wipes off easily with a a damp rag, but I highly recommend covering what you can with sandwich/Glad wrap to stop 1) the wet plaster sticking to anything when you first mix it up and it's setting and 2) the dry plaster marking everything it touches which white marks when you're fitting up any template to parts of the interior.
Great idea, looks good.
I dont have a creative bone in my body so could you please explain how you did the reverse moulds?
If you look at the pic on this post you'll hopefully see that the template is half blue, half white. What I did was mix some blue food colouring with water and dipped half of the plaster template into the water. Just like the old Colgate toothpaste ads on TV :laugh: This line that runs down the length of the template and over the face separates it into about halves. So I mixed up another batch of plaster of paris, poured it into plastic container, waited for it to set a bit and then pushed the blue/white template (blue side down) into this plaster up to the line so that no more blue was showing. Waited for it to 95% set and pulled out the template. Then I mixed up another batch of plaster and pushed in the template (white side down this time) so that no more white was showing. What you should end up with two reverse (negative moulds) of the 2 halves of the gauge pod - which you can seal with wax, coat in a release agent (or oil) and fibreglass in them. Then pull the two pieces of fibreglass out, clean off the release agent and fibreglass the two seperate halves together.
I hope that makes sense.
NOTE : Make sure you cover the template in Vaseline before you push it into the plaster, otherwise you'll never get it out!
The final product, painted matt black (which matches the dash very well and doesn't reflect any sunlight).
For those of you who are curious, the 3 orange and 1 red LEDs under the boost gauge are for my Axis/Hyperform shift light.
Total Cost was ~$50
With something as light as that double sided sticky tape would be ok, Also wouldnt leave marks on the dash if you wanted to sell the car.
BTW great work im now thinking about doing that for my 32
that looks cool man how much are you going to charge to seel them and how are you keeping it from moving
I wasn't thinking of selling any in the immediate future but in the long term I may look into how much it would be to get them manufactured in a ABS plastic or something similar, but don't hold your breath. Hence this thread to show people how to make them. Although, depending on feedback/demand ....
As for holding it down, it doesn't actually need anything at all. There is a lip at the back of the dash which the back part of the pod stops it from moving back/front and at the front of the pod where it's contoured to the dash stops it from moving left/right. I was running 12psi tonight (on a cool 12degC evening) and at WOT & fast cornering and it didn't move at all. But the bottom of the pod is slightly raised from the dash level to allow to double sided tape/velcro just in case.
  • 2 months later...
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
