Hey, any picures of the mod you did? what fitting did you use for the return from the rail?
I have modified a few rails in my time, but the stock 34 rail flows stupid amounts of fuel. What are you trying to do?
Well i already have a new Nismo FPR etc so rather than going out and buying a new rail and FPR, i was looking into how much HP the stock rail would handle, from what i can gather making the stock rails return larger should do the trick, was just interested to know if its been done/works etc....
Looking at over 700HP once its all put together and tuned.
You can run a Nismo reg off an aftermarket rail if you don't think the stock rail will flow enough. Either way I would run a gauge inline to check the pressure doesn't spike anywhere or drop on load.
What pump/s are you planning to use?
  • Like 1
Was just going to run twin 044's, still need to speak to the tuner about that though, who makes that regulator adaptor to suit after market rails?
Will still be running on 98 pump fuel (as we dont have E85 on pump here) and it is still a daily driver.
I would just run an e85 Walbro, should flow 600 odd kw on 98 and would be much easier to fit intank. If you have a surge tank etc, try and stick to a single large pump, as if one 044 fails you won't know until it leans out at WOT.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
