Saluations All.
This maybe obvious to some, and others may pretend to know.
But I've just picked up a new clutch. it appears to of the brass (? brass) button (the plate has five separate fingers with pads on each) type.
I've been told it'll hold onto 200RwKw easily (I'm no where near that). But I've also bveen told that if you don't know what your doing you can wear a button clutch out in a very very very very very very short time if you ride it - which of course is bad in any clutch.
I'm just interested how I'll have to adjust my driving style with this clutch, will I wear the clutch out if you ease off the lights, does it have to be rev and dump at every lights to protect the clutch ?
I don't ride the clutch at all unless I'm parking or doing general driving to work (rarely) and need to ease of the light...Will I wear the clutch out quickly from just this ? I take it, it will be a new expirence in the wet too!
PS. Its a R33GTS-t and the clutch was from a southern import jap shop.
Thanks any ifo/comments would help.
ps...why is a five finger clutch stronger then a full face ? I thought the more area of contact the stronger clamping you'd get.
Andrew
https://www.sau.com.au/forums/topic/1128-clutchs/
The paddle/finger/button clutch is made of a different material, and the smaller area means more pressure on the paddles. From what I've been told do not ride the clutch at all, you should get used to taking off gently without riding it. It will never be as gentle as a sprung organic (Standard) clutch though.
Near the centre it's either a solid centre, or has a set of springs. The solid centre has NO give at all whereas sprung button clutch is slightly less harsh.
After having a sprung button in my car I will never go back, the sheer grip that it has is unreal, however the loss of smooth gear changes may not suit everyone.
https://www.sau.com.au/forums/topic/1128-clutchs/#findComment-23333
Jimbo.... Dude, the twin plates are the next step up again from a button clutch. These have extreme clamping pressure and very high friction co-efficients. They are basicly on or off.... If you went back to a single plate clutch you may get smoother take off, but replace your clutch every month or two due to it not being able to cope with the power.
Sorry pal, that's the price of high performance, loss of comfort.
All I know is that I'd take performance over comfort anyday :uh-huh:
https://www.sau.com.au/forums/topic/1128-clutchs/#findComment-24019
I'm more than happy to use the clutch how it's meant to be used (on/off) but I've never driven a multiplate clutch before so I have no idea what I'm meant to do ;) I know it sounds dumb, but I'd love to ride with someone who has a multiplate and knows how to use it.
I'm certainly not after comfort, I just don't want the cops after me at every set of lights for losing traction, also how the hell are you meant to drive in city traffic ala. Parramatta Road ? I don't know about anyone else with a multiplate clutch, but I manage to look like a bunny wabbit on extasy trying to move along at a snails pace ......
https://www.sau.com.au/forums/topic/1128-clutchs/#findComment-24140
thats one of the many reasons i like working nights.
my 5 puck brasser ain't no twin plate, but smooth launchs can be difficult sometimes too... night shift = no traffic. I have stopped and waited before for the traffic to ease up cause my leg gets tired. ;)
https://www.sau.com.au/forums/topic/1128-clutchs/#findComment-24294
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
