Was wondering what sort of times and mph most quick cars were running to the half track down the quarter. By quick i mean 10 sec cars using ET Streets or BFG's with pump fuel. Not fussed about slick tyred cars or cars running NOS.
The best 660 i have run is a 7.280 at 95.77mph.... but was wondering what half track i need to see to be confident the car will run mid to low 10's.
I basically want to run some half track passes and be sure the car will run a mid to low 10 before i get booted for not having the appropriate safety gear
Brad
Brad
IDO11s,
In a late model IRS car I'd say you'd be pulling 110 MPH at half track to run a low ten second pass. 660' time would be 6.6-6.7s?
IDO11s,
6.5 @ 110 is on the money for a low ten
for a high ten see Adrians previous post.
I have a better idea....let Andrea have a go....i think she deserves a try before the car gets banned.
Edited by DiRTgarage
thanks for all the replies guys. I was hoping i wasnt to far off the money but it appears i am still a fair way from what i need to be. Hopefully the new found power will help but i guess only time will tell. Bring on Friday!!!
Paul, i tried talking Andrea into racing it herself but she isnt worried about having a steer.... for some reason all she is worried about is the car going fast and it sadens me to think she hasnt even been able to enjoy it herself. But, its her choice and i guess i just have to accept it. I just hope i can do all the work we have put into the car justice this Friday and run a decent time with it. It will make both of us very happy if i can :):P
Paul, i tried talking Andrea into racing it herself but she isnt worried about having a steer.... for some reason all she is worried about is the car going fast and it sadens me to think she hasnt even been able to enjoy it herself. But, its her choice and i guess i just have to accept it. I just hope i can do all the work we have put into the car justice this Friday and run a decent time with it. It will make both of us very happy if i can :(:P
Ive seen first hand the upgrades you have done since last time at the track, id say the 10's in the bag!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
