  • Replies 86
btw - i hit the drags tons.
You wont need any licenses etc.
Just make sure you have helmet and long sleeved clothes and long sleeved pants.
The $36 Entry fee or whatever includes 1 pit crew as well, so thats 1 spectator. So sort that out so someone is in with each person and it all gets cheap.
These days you can easily expect 10 runs if you want it....
mick
just let me know if u need it, shoei full face motorbike helmet, i bought it to go out to QR with. Dont think my car will be going for a run after thinkin about it so send me a PM, happy to just watch this time...
You clutch won't be ready for pick up until tuesday arvo so I can get it done on Wednesday for you.
As long as you give it 50km or so of easy driving to bed it in...you won't have a drama. Like I said...it's like a super sports organic so you won't have any problems with it. If you drop it in first thing on Wednesday I should have it ready to go for you before 11.
I also need a helmet but seeing as though I have such a doofus head, I am going to borrow one of a mate.
Looks like next wednesday might be the go for everyone at this point so I guess we'll make it then. Tomorrow is probably too little notice for everyone and I don't wanna head out unless I have someone there I know that might be able to drive me home when the g/box explodes lol.
Was there the week before last. Entry fee for racers: $36 per car( driver+1 spectator), Driver must wear long sleeves and long pants, plus a helmet. Actually you can share 1 between 2 cars, I did that last time since I dont have one. Just tell the lady you will share the helmet with ur friend.
should be about the same price for 2 spectators.... So I reckon go there and race better than just watch. Wednesday would be a better choice, since Fri would be more cars there. Last time, I was able to get at least 8 runs, but gave up after the sixth, since my car's so slow........ Will talk to you soon, Dan.
Edited by RYN26
No problem dan.. i'll still head out to support those running tho, wouldn't wanna lean on teh new clutch too much. PM sent about clutch booking too ;)
Not sure what size my helmet is, think its an XL/ 60cm give or take a cm or so..
I might be popping out there for this, give the sedan its first run down the strip. Most likely on the Friday, might be the end of the clutch though. . . . . oh well ;)
I will aim for a low 14, should be able to get the stocko down there somewhere.
I'm in for Wednesday!! And Dan I have a boof head and a good helmet if you want to share?? No cooties.... honest....
Oh, the car is fixed and it cost a lot less than I expected!! Cracked manifold and 3 sheared bolts!! All better now and runs even better!!
I could be interested for Wednesday..really want to see what the car can do before the new turbo ect! Hmmm what time do I want???? I guess for my first run I would be happy with making it to the end LOL
Thought it might be Dave. When I got mine it had the same thing and apparantley its a common thing for RB25s. They run sooo much better when its all fixed up. . . . which is to be expected I suppose.
Mine, the crack went right around and when I tapped it on the ground it broke in half!
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
