Hey guys,
I am getting a brand new stainless steel 3" turbo back system with high flowed cat installed on my r32 tommorow. At the moment i have a very cheap 3" cat back that came with the car when i bought it. It drones terribly and at 80km/h i can barely hold a conversation in my car without yelling which is the main reason for the upgrade.
But what i was wondering, was will the new exhaust with dump pipe and high flowed cat give much better performance than the current system i have?
Cheers guys
https://www.sau.com.au/forums/topic/113354-r32-gts-t-3-turbo-back-system-power/
Well turns out I wont be gettin system today because of delays, but the guy gettin it in for me confused me. I asked him if it was definately turbo back and he said no, but it has a dump pipe?? My understanding was that a dump pipe is a pipe from the turbo back to the cat, meaning if you have a dump pipe you have a turbo back system??
Is that correct?
not quite...
turbo bolts onto dump pipe then to front pipe, then to cat, then cat-back
an aftermarket 3" cat back won't give any power increase over another 3" cat-back
the difference will come from fitting a dump/front pipe and the high-flow cat...
good luck,
Warren
I should've clairifed.
Turbo back system consists of (in order of fitment)
Dump-pipe:
Front pipe:
Hi flow cat:
then
Catback + mufflers
You can also get front+dump pipe all in one pipe.
Thanks heaps for the help guys.
I'll have to wait and see if i have got a dump/front pipe all in one, but im thinking it will be, cause i looked on the website for the company that make them and it says 'Full turbo system'. Heres hoping anyway, im thinkin the entire system should resemble something like this...
Cheers
i fitted a front pipe and dump to my r33. it already had a cat back, made a huge difference to the overall power of the vehicle, u will certainly notice it, as well as the increased volume of the turbo sp00ling too :P
i fitted a front pipe and dump to my r33. it already had a cat back, made a huge difference to the overall power of the vehicle, u will certainly notice it, as well as the increased volume of the turbo sp00ling too ;)
Gota love the sound of a turbo spooling, after i had my dump and front pipe put into my cat back system that was on the car from Jap it goes harder up in the revs and sounds sweet.
Cheers
hey,
Is it true that to modify the exhaust on the R33, changing the stock dump pipe is not necessary? I heard its quite good stock, so unless u got an aftermarket turbo a front pipe back exhaust will be just as good as turbo back.
Can anyone back this up?
Is it worth getting the dump pipe as well?
Cheers
Get a compleate system, if you have seen the stock dump its a peice of shit, thats why there is reasonable gains to be had.
So get any 3inch split dump?
What do u think of the cheap E-bay ones? Anything wrong with them?
cheers
r32line what kind of turbo back exhaust did you purchase?
and what do you all think is a better option for i: batmbl split dump front brand new + cat + second hand catback OR a full xforce system for $700?
From what i've heard SOME of the ebay dump pipes are okay, they're still a large improvement over stock.
Not sure about the HKS split dump pipe copies on ebay though, apparently BATMBL's longer wastegate chamber is better suited for reducing turbulence as it re-connects further down the pipe.
Anyone care to elaborate here?
Edited by MintR33
I have always maintained the former. I would always go with that if I needed to upgrade a stock exhaust system.
I trust batmbl's pipes because they look like a good design, lots of people have made power on them and he's a good guy to deal with.
The second hand cat back you can inspect and make sure has no kinks etc and you can wash it out. For a metal pipe as long as it flows as good as it came out of the factory it's going to do it's job - it doesn't matter if some crazy Nihonjin has used it already :bomb_ie:
i have a front pipe from just jap, no cat back just the pipe so all u here is turbo spool lol, im waiting on my cat back rein hard thats on teh way,
my pipe was all one peice from turbo to the cat,
my front pipe lets me drive at alot lower revs and less "boggin down" around the streets, u can feel teh restriction when the flow starts moving more, should all change soo enough
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
