hi guys,
my hicas light is constantly on what does this mean? can someone help please?
Mine was coming on only at low speed and then the car would cut out alltogether, got my car serviced this week,my hicas was fine but the problem was caused by my revs being too low, since then no probs..but if yours is on all the time I would get it checked asap..
mine keeps coming on after a few kms but the stupid hicas is still on, why oh why nissan put this in their skylines i wonder!
you could always get nissan to check it out and pay a billion dollars to fix it? :domokun:
Edited by NeesaanGTS
Common problem apparently, many causes. I just got mine fixed the other week, the actual HICAS computer was f**ked. Replaced it with a 2nd hand one and no more problems. But its very rare the problem is the actual computer.
Edited by Xizor
hey there
another common problem apart from those already mentioned is that if the steering wheel has been removed, and the hicas steering angle sensor isn't set at the correct position, the computer will think you're driving in circles doing whatever speeds, and so will put up the light to say there must be a malfunction..
its possible.. my gtr was like it when i got it...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
