Just got myself a r33 front and rear calipers. Previous owner painted it in YUCKY sky blue colour.
Just wondering what do u think is the best way to remove the paint? I'm planning to leave it unpainted.
cheers
Edited by freshjive
I used a pressure-pack can of paint stripper. Works a treat - much less hassle than using the paste/gel.
Just so you know, the bare metal looks like poo.
n.b. you can see the paint stripper top left of pic - the brand is Motorspray or something like that.
Hope it helps, :(
No problem, hope it helps.
I used an old rag to wipe off most of the residue, then used an old brush to clean out the rest from in between letters and other hard-to-reach places. Once the paint blisters, it wipes away like dried cake icing - most of it just flakes away then you go back and clean the last little bits.
To clean it after stripping, I used some prepsol but most wax/grease removers will do the trick. Don't let the Repco dude talk you into buying a 4L tin. I bought a 1L and barely used 10% of it.
Cheers
Mark
ps who's the chick in your avatar? Looks familiar but I can't place it.
Hmmm....hope this joggs your mind :P
Pic
I got the pics for my avatar from Need For Speed Underground :ermm:
Anyway thanks again! I will give it a try this weekend.
Cheers!
Edited by freshjive
NFSU! That must have been it. Cheers dude.
For the seals you'll need some rubber lubricant (man that sounds dodgy). Lets call it rubber grease. :laugh: How about frictionless paste?
Seriously though, if the pistons are still in the caliper, you'll need compressed air to pop them out. They are bit of a pain in the butt trying to get all four out at the same time - as soon as you pop one, you lose air pressure and have to start over.
I apologise if you know all this already, but don't bother with the 'one-man' bleeders. I tried twice and both times had a squishy pedal. Used a mate and sorted it first go. Remember to bleed the ABS once all the calipers are done.
Assuming you have the shims, make sure you apply some anti-squeal paste.
Once again, I don't mean to ask you to suck eggs, just trying to help. I'm pretty sure the R33 calipers are the same as R32 GTR - if you don't have the reco kit you could search for a thread titled "What is a caliper overhaul" and the part numbers are half-way down on the first page of the thread.
Cheers
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
