I was trying to fit my tomei poncams last night and everything was fine until........
I tried to fit the Cas unit to the front of the exhaust cam, its got a different kind of 'conection'.
Is there a difference between some of the rb25's cas unit? Mine has teeth and one locating lug that sticks out, the cam has two locating lugs...
I live in the uk and bought the cams from nengun so I am going to have to find some way of making them work, even If i have to buy a different Cas unit.
please help, anyone with photos of diffenert cas or cams?
thanks
Tom
Edited by tom200
https://www.sau.com.au/forums/topic/114187-rb25det-tomei-poncams-problem/
also believe that the base circle is different on them too..
what is the product serial number for the cams you have ?
what is the month and year of your car as well??
pre oct 97 R33's all use the same cam regardless of series.. post oct 97 use the Series 2 option poncam, then r34 is different again.
The month and year of the car is unknown as its in my s13and I forgot he car I got it out of...... oh well...
I do know its a series two, I think it was a 96 or 97.
The cams came in a box that I chucked out, but they were for an r33. Maybe a late on with the r34 cas??
I have spoken to some guys here in the uk and I'm sure I have r34 cams so I'm going to fit r34 cas.
Thanks for the help lads.
Tom
143050
ECR33 Series 2 (RB25DET) - Duration: IN, EX 256 Lift: IN,EX 8.5mm
Thats what its says on the nengun web site.
So if I have these cams and they dont fit???? I must have a series 1 motor? unless thery sent the wrong ones... but i chucked the box now.
How can I tell quickly if i have a series 1?
Can someone post a photo of series 1 and 2 or r34 cas? I just want to know what car has the cas driven by these cams.
thanks
Tom
Edited by tom200
thanks
Tom
If you have a series one you should have a ignitor unit at the end of your coil pack rack at the back of the engine on the black plastic cover. Series 2 25's dont have a seperate ignitor pack.
also the throttle position sensor will look like a single unit on the S1 and look like a double on a series 2 .. but that still doesn't help the fact that a S2 made before oct 97 will still not be able to use these.
thanks
Tom
get a r34 or my98 onward r33 crank angle sensor. or buy new cams. you can sell your existing crankangle sensor easy enough.
not sure on base circle but
and you need to swap the two triger wires around in the plug.. ie green/yellow green/red i think. the black ones earth the black/white is power
Ok mine is a series 1. it has the ignitor at the back on the top.
I'm thinking these are series 2 cams as I cant see how they woulb send r34 ones and i'm sure the box said r33 rb25det.
Is it ok to swap series1/2 cas. how much are they on here as I only found one tuner over here and they want nerly $1200au . that was for the r34 though.
I still would like to find an image of what cams / cas haved what drive, just to be sure what I have.
If they are 34 cams i'll just sell them.
I quickly made this models up to show what the difference is. If anyone can be sure what the tomei one is for, then please tell me.
My old cams have this to drive the cas - images 1 and 3
the tomei cams have this kind of drive, anyone know what car this is for? - images 2 and 4
once again, thanks for the help.
Tom
old tomei old tomei
Edited by tom200
  • 3 months later...
I am bumping this thread up because I seem to have the same problem. My motor is a SII rb25det (without ignitor). I just bought some tomei poncams part# 143050 and the cam angle sensor is different. Is it confirmed that I have to get an r34 cas and that it will work with my motor?
-Bluefire
  • 4 years later...
Bump :)
Was this ever resolved? What cams are in the very late S2's with the black CAS? Is it cams from the Neo engine???
According to wiki the RB25DET and Neo cams are different profile:
RB25DET Camshaft duration 240°in, 240°ex lift: 7.8mm in, 7.8mm ex
RB25DET NEO Camshaft duration 236°in, 232°ex lift: 8.4mm in, 8.7mm ex
So Nissan would have either have had to machine a special cam to accept the black CAS, or just take the upcoming Neo cam - when they were building the very late S2's.
Edited by Tony de Wonderful
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
