For any 1 looking around for a good performance work shop pop in and see the guys
at AMBERLEY AUTOS in
12-14 Amberley cresent Dandenong
PH-97931616or go have a look at
www.amberleyautos.com.au
they have the lot 4wd dyno just to mention 1
so really worth a look ......
https://www.sau.com.au/forums/topic/114209-they-fixed-my-car/
Well it ended up being 3 things causing the drana.
the stalling was stopped by replacing the Airflow meter
then that left me me with splutteringon under acceleration
witch turned out to be a air leak from the throttle enter pipe .
that didnt fix it 100%so they ripped out the plugs and found
the gaps to be to big so they re -gaped then now its 100% could not be happy a....
i've been there a couple times with a mate who gets his wrx serviced there and he swears by them. They are very good at what they do, and they aren't bullshit artists. Plus there is a chick mechanic there who reminds me of the chick from gone in 60 seconds.lol. Plus they allways got imports, wrx's there. They are allways busy
YEah good people ... Ian is a very thorough man and has looked after a few of my mates...
Lebostyles:
yeah thats Tanya if i remember correctly... i remember the look on my mates face a few years back when she took his 200 for a test ride after being dyno'd.... nothin but the smell of rubber
Lebostyles:
yeah man, and these people reckon im on drugs :(
Don't you mean HORSEPOWER FACTORY! They changed their name.
' date='20 Apr 2006, 12:20 AM' post='2103578']
riiiiite
Come on [WLDCRD] I hear they give good roadworthy.
Are you talking about Tanya?
yeah tanya, i think there still called amberly's but there performance shop is call horsepower factory. but i could be wrong
YEah good people ... i remember the look on my mates face a few years back when she took his 200 for a test ride after being dyno'd.... nothin but the smell of rubber
so he was pleased that his 200 was thrashed by someone other than him?
hmmm...
I agree HPF are awesome, just too far away for me. :)
A mate of mine's family has all their cars done their. The mum drives a 300rwkw stroked/charged AU2 XR8. But the best is the dads, new BA GT-P twin turbo (427rwkw stage one, stock internals). And cause its the research car for a kit, and they had the car for 2 months longer than quoted they got it all done free.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
