Now that sounds better. I fill my car up to the maximum limit it can hold. (65L), i drive it all the way untill it literally hits the end of the empty line, i go to fill it up, it only takes about 35-40L. Its still got around 20L left of petrol yet it says its empty. The light doesnt come up or anything, im just too scared to risk it incase. Ive heard this is pretty common in skylines, anyone know? Any possible fix to this if any?
It's pretty common on most cars, I think it's a design thing, to stop people running out of petrol. The common thing to do is fill it up when it gets low. Why do you want to run the tank dry? Low fuel warning light usually comes on when the tank has ~10L of petrol left, but this varies with cars.
I've put a new fuel sender in the tank and it hardly changed. The light doesn't come on until the needle goes just past the 'E' it's about 10L left when your needle drops about 1mm under the 'E' on the factory gauge.
Best only do that if you need to change a fuel pump.
You won't find a car (with a working fuel gauge) that doesn't have the fuel light come on with about 10l left in the tank. This is so when the light comes on you have enough fuel to get to a servo. No point having the low warning light come on and the having it run out of fuel 5 seconds later.
I know, and i agree it would be really stupid for it to come on with only 5 seconds left of fuel. I just find it odd that it says im on empty, yet i fill it up and it only takes about 40L of petrol, thats still 25L of petrol left. One day i drove it around for a couple days when the needle was on empty. Eventually i went to fill up because i thought the fuel light would of turned on by now, so i thought maybe my car doesnt have one. It only took 40L, i was thinking it was going to take atleast 55L of petrol before being completely full again. So thats why im thinking i need a new fuel sender but thought id better ask the people on these forums before i waste money on something not needed. Im not complaining that much though, better safe then sorry, just that fuel reading is very misleading.
Now that i know the fuel warning light comes on with 10L of petrol left, im going to top it all the way up and drive it until the light comes on and see how much km i get out of 55L of petrol. I guess im hoping for atleast 450km out of 55L.
Edited by Gw2
There is a few things you can do. First, reset your odometer everytime you fill up, then just run it till the needle is pretty much spot on the empty line. Then take note how many litres it takes to fill it. Then you can work out your average economy and then work out how much further you could drive based off how much is generally left in the tank when the needle is on the empty line. This method will give you an accurate way to calculate how much fuel you've used and how much is left down to a few litres. Much more accurately than any fuel gauge as they can work in funny ways depending on tank shape. For example, I've had 2 cars where I could drive close to 150kms before the gauge moved from full, yet my current car will be down to 3/4 after that distance, but yet the last 1/4 (from 1/4 to the empty line) I can do close to 300kms.
But I don't see what the problem is really. Just fill up when you want/need to. It makes difference to whether you fill up with 20l left or 10l left. Your economy will be the same, and in the long run it still costs the same.
Yeah, plus 4cyl rego is cheaper than 6cyl rego. I work between 4 and 6 days a week and drive about 125km (round trip) to and from work everyday. The Commodore got about 8.8l/100kms, the mirage gets just over 6l/100kms (best I've gotten was 5.7l/100kms).
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
