  • Replies 240
Sif.
Bring it, Bish.
I stand by what I said.
Heh will submit my essay later after work. Base physics seem to be overlooked, so will have to include a chapter on that and basic mechanics as well.
Oh and if it was only oil surge/spun bearing, why does piston 5 have alot of detonation peppering?
Sif.
Bring it, Bish.
3L bottom ends help ONLY with low end torque/tractability (good for general street use, yes)
BUT
The shorter stroke RB26 based engines are ALWAYS a better idea as out-and-out race engines, for all the reasons I mentioned and more.
Need I remind you that the 3 fastest drag GT-Rs on the planet use 2.8L or smaller engines, with the HKS 33 using their own 2.8L kit (crank has 4mm more stroke than normal [77.7mm])
But I'm sure in your mind the 3/3.1L jobbies are better, right?
Your a gimp, for those of us that don't own a multi million dollar company ie HKS and build a car from our own catalogue and aren't trying to be one of the 3 fastest GTR's on the planet tell my why a 3L isn't a good way to go for a RWD car for someone unlike yourself that has some description of a budget?
oh and with all this knowledge you posses what have you built or done with your car?
oh and with all this knowledge you posess what have you built or done with your car?
tehehehe he said gimp :sick:
*sigh*
Oh dear...Seems I've offended the 'RB30 bottom end' crew.
Gimp suit in the wash at the mo'. It's just regular old Shaun for today *LOL*
Look,I'm sure an 3-3.1L RB with a twin-cam head can make lots of power and is great fun, and I know it CAN work very well (Wilall racing as an example, especially [yes, yes- that's an OS Giken kit]), and I didn't mean to step on the toes of anyone that's gone to the trouble of doing the conversion themselves.
But I just don't think that using the 85mm stroke crank from an RB30 is the best idea for engine longevity/reliability at high engine speeds.
But it's all relative.
To be at the pointy end of 1/4 mile competition, you would be rebuilding/pulling down the engine on a fairly regular basis (in comparison to a mildly hotted up performance engine, anyway) to make sure everything was still o.k
Like I mentioned in my original post
'ALL THINGS BEING EQUAL'- i.e rod/piston strength & weight, the shorter stroke engine will be able to rev higher, before mechanical limits come into play, due to the lower piston speed.
More revs = more combustion cycles per unit time = more torque = more power (if the motor is designed/blueprinted for it)
Yes, the 3L has more capacity (approx 66cc per chamber, wow), but, within this engine design, IMHO it's not as important as the rev limit of the motor with regards to how easily it makes big (v.big) power.
Hope this clears things up
p.s Wil- no more taking my posts out of Whoretown :sick:
So am I'm missing something? Mona shouldn't go RB30 bottom end because she'll need to rev it to 15krpm?
Some of the VL guys down south ROUTINELY rev their VL RB30 combos past 9krpm - one sees 11krpm from time to time.
In other words - I don't see your point.
Dude with every post there are more misconceptions brought into the equation. You start off talking about a street motor on pump fuel, then jump to quickest GTRs in the world, then back again to street motors and longevity, and then talk about theory and limits.
Throughout all of this you've thrown in misleading statements, outrageous and unverified claims, and total bullshit.
I only get my back up over misleading information, if you want to go ahead and talk up RB26 combinations go for it - I really don't care. But other people can and will get the wrong idea over misinformation, which isn't a good thing.
For anyone who still cares:
Nissan had the RB30 design from the mid 80's
The RB26 came out in the late 80's
They could have used the 3L engine in their soon to be all-conquering 'group A homologation' race special (ie R32 GT-R)
Can anyone give me a coherent, logical reason why they chose to design an engine with 2568cc capacity rather than just use a twincam head on a balanced and strengthened version of an engine they already had- that was 2962cc?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
