try www.fulllock.com/superhappy theyve got some pretty random stuff there.
and try some parts shops like d1garage.com, justjap.com
but if your after brand newies, your gonna have to fork out the $113
  • 3 months later...
i just got a perfect condition vent free from a half cut that was being thrown out from my friendly local workshop last week.
FWIW a vent sold on ebay for $50 a couple of weeks ago....keep looking
Edited by SLIPPERY
I need some vents also, but I was thinking....
Surely it's possible to get a better solution than replacing them with stock items?
Does anyone know of someone who makes them form (say) aluminium? Maybe some harder wearing plastic?
Because I get the feeling that buying second hand will just make the problem come back in 12 months, and even buying new might only give a year or two of respite.
I bought new around a year ago and they feel the same as when I put them in. I just make sure I use a sunshade when I park at work - stops the vents from perishing and the dash from lifting :(
I'd hazard a guess that aluminium would be more expensive than two or three new vents
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
