hey ppl i got a 93 gtst manual which consits of
-Front mount
-pod filter
-full 3 inch exhaust with split dump/front from batmbl
-greddy boost controller set to 11 psi
the results were 181.1HP
max hp came in at about 5100 rpm however my boost seemed to drop back to stock psi as the revs got higher any idea ? the guys at hyperdrive said the ebc might not hav been set up properly il try ge ta pic of the dyno sheet asap
cheers sam
Edited by Sammie
https://www.sau.com.au/forums/topic/115128-had-my-car-dynoed-today/
  • Replies 104
Posted Images
i think they came with the RB20DE and RB20E, not the RB20DET though. I would say its a RB25DET. 181rwhp @ Hyperdrive seems a little low, im gonna go there in a few weeks to get mine tuned. I have same mods with SAFC II and no boost controller. will compare it to that once done.
yea its a rb25 guys the bloke there said i should be looking at getting a power fc just was dissapointed hearing ppl with the same amount of mods reaching 200 + was kinda hoping for atelast 200
sorry but thats a bit ambitious...
the boost is probably too high for the stock computer for a start...that wont help...other than that you've got an exhaust and a pod....
justin911 for example is just making 200rwkw and has full 3 inch zorst, fmic, 12psi and power fc...
you may have read rong it perolly sed 181.1kws???
I seem to agree with Supadan.
While power figures do vary from car to car and dyno to dyno, it does seem like a fairly low power output for the mods you have listed.
Assuming that everything is running properly, and AFR's are good i'd be expecting higher myself. 180kw's sounds realistic. 180 hp seems low.
But like I said, the low power could be due to any number of things.
Dyno readings aren't gospel.
Edited by insu
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
