RE - The pic below...
I have a brass nut which my temperature probe fits into and will be using it to measure intake temps. What is this intake piece (circled in red in the pic) made from? Cast Aluminium? Can it be soldered/brazed/welded to brass at all?
If not, how else can I join this brass nut onto the intake pipe? Maybe a steel washer between the brass nut and intake pipe?
https://www.sau.com.au/forums/topic/115141-what-is-this-intake-pipe-made-from/
I'm looking to do much the same thing! I'd really like to know what the intake temps are, and find a good location to mount something threaded. If you don't mind, mearcat, what kind of temp probe are you going to use? (and come round and make my engine bay as clean as yours!)
I'm actually measuring 4 temps, with 3 of them using a K-Type thermocouple probe - mainly designed for testing flue gasses. I'll PM you with more details
As for the engine bay - it came like that from Japan a few months ago! Nice eh? :P
Why not simply tap a hole into the cross-over pipe, and screw the temp probe directly, rather than through an adapter?
I did think of that but I talked a welder this morning and he said that the wall thickness of the cross over pipe is not really thick enough for a decent thread for (relatively soft) aluminium. I have got him to weld a small block of ally on the side on the pipe to increase the thickness and tap a thread through that block and the pipe wall instead.
So I will now end up screwing the probes' compression gland directly into the pipe.
wow! Great read, Mearcat!
I only want the intake temp... would you suggest that a thermistor for budget/heat-range?
Pity that I can't find a decent threaded temp probe with display... I spent aaages making the consult cable, and I don't have much time on my hands these days. =[
If you wanted to read a single temp, as a cheap option I would suggest this thermometer from Jaycar http://www.jaycar.com.au/productView.asp?ID=XC0224 These are quite accurate and if the cable isn't long enough, you can solder some more wire on it without affecting it's accuracy too much. This reads from -50degC to +150degC too.
My temperature gauge project is using thermocouples with braided stainless sheath to stop the wiring from frying around the turbo and engine - they are a little more expensive that std thermocouples that you get from Jaycar etc, but temperature probes and thermocouples genarally are not threaded. You will need a compression gland to seal around the probe.
btw - See the attached pic for my weld & thread tap result
LOL! I have been looking at that unit for a while actually!
I was a bit concerned about how hard it may be making it sit in a hole, but the gland option is always there. Threaded like the o2 or cat sensor would have been nice though.
Weld/tap job looks good!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
