Hey how are you, I've been looking for the same thing for quite a while, & as far as jap bolt on's are concerned there is stuff all available. There is an Apexi 1 that nengun sells I believe as stated above but it's only got a 2.5 inch inlet. Kakimoto did make one, but it's discontinued much to my dissapointment. The only other alternative I know of is Reinhard, but they're meant to be 95 dB according to 1 place that sells it even when they are silenced!!
If you really want a twin tip muffler that's not too loud however, go and get a custom system, I'm about to be doing the same myself as I've been searching for several months & apart from what I have mentioned have found nothing. So I wouldn't spend too much time searching if I were you.
Mines one of two that were im ported by option 1 garage, I got it a couple of years ago when the "Canon" Muffler phase was at its peak, but I wanted a twin system, took me ages to find mine.
Its a Fujitsubo. I beleive this model is now discontinued though :devil:
Edited by MintR33
heres mine, pretty sure its an X-Force ..
3" inlet.
although i am going to have to find a way to run 2 of them..
edit: this tip is now a gold colour since its stainless
Edited by Craved
I'm planning to mod a stock R33 muffler. Chop off the in and out pipes, then weld on bigger pipes, open up the muffler, and convert it into a "straight through" kind of design using baffled tubes.
Making it fit the Nismo 3" catback section will be tricky, methinks!
Currently looking for a used muffler, so I don't have to cut mine up!
Its a Fujitsubo. I beleive this model is now discontinued though :)
Yeah I had heard that they had made 1, but couldn't confirm it.......... bastards! Well it's cost them a sale cos I would have bought one of those, that looks just nice. Is it twin 3 inch?
Cheers guys.
Dam Electro that is not what i wanted to here :)
MintR33 that is hot, i would love something like that pity it is discontinued.
I wonder if i could source a 2nd hand one.
Yeah sorry mate, but at least you don't need to go through all the crap of trying so hard to find 1 you could cry :O .
By the way I doubt you'll find a second hand twin Fuji since as MintR33 indicated they are very rare. Not unless someone happens to be upgrading to a 3.5 inch system that has 1. Sorry again.
I'm going to be getting a custom 3 inch system with JunBL Muffler & custom tips, will show you what it looks like when it's done. Will probably be a couple of weeks.
  • 4 weeks later...
Same here
Im looking for a twin outlet exhaust system. The drift brand that autobarn advertise in HPI have one, and the other that i have seen is the Reinhard (look damn cool though). Ive got a sedan and have an x-force 3in system with a barrel muffler, little did i know when i bought it, that it was the "angled" type and looks a bit strange sticking out to the side, as it sits too close to the bumper :O. So im looking for a nice dual outlet muffler like the reinhard - dual separate mufflers, 3in inlet -> 2 x 2 1/2in - 3in barrels? Wonder if that decibel rating is just the muffler or a catback system?
cheers
Evil
I got rid of my 4inch cannon HKS race muffler, for a custom 3inch straight through sports muffler. I had it custom made, its gotta be one of the biggest bodied mufflers going!! Id say 50cm x 35cm x 25cm, its 3inch straight thru, with twin 3inch tips. Knocked about 20-25 decibels off my GTR, Quick fit Mufflers made it up for me, took about a week..
Edited by mazgtr
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
