I have an r33 gtst. It has a-lsd (i have the lights on my dash) and it does appear to be working because the light does come on when I lose traction.
I have a bottle of oil in the right hand side of my boot.
I was wondering, how do I change the fluid in this system and what fluid do I use?
The reason why I am wanting to do this, is to hopefully make it more responsive.
Surely someone with an r33 or r34 gtr vspec has done this before?
Cheers
https://www.sau.com.au/forums/topic/115298-a-lsd/
I also have an A-lsd, and i'm not 100% sure on the process of removing the old fluid and replacing.
One would assume there would be a drain plug somewhere probably around where the lines come down to the diff, and possibly a filter of some description? Maybe not.
I know to replace the fluid you are to use automatic transmittion fluid.
You might be best off pm'ing paulr33, I know he has an A-Lsd and seems to know a bit about them, so i'd give him a go.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2136798
I was actually inspecting the unit today, and i seemed to notice a bleed nozel sorta like the brake caliper.
Also, I don't think the fluid is ATF. My jap owner seems to have put atf into the tank on top of the existing fluid. It just floats ontop of the other stuff (which is black). i'm guessing it uses attessa fluid?
I remember looking at a schematic diaqram for it before and it also uses oil pumps and stuff too.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137682
Now, gtrs come with 2 way mech diffs. Vspec comes with these diffs, so surely they must be better? Doesn't feel like it to me though. There are a few more things that I have observed:
My car has got the vspec diff with the finned cover.
I have the fluid tank in the right of the boot
I have the slip/a-lsd lights.
So I guess I could say that it's pretty certain I have A-LSD.
If I drop the clutch, the Slip light comes on and both wheels do spin.
My issue with the diff, is it seems to be quite lazy. I'll elaborate on this further.
I've been in a car with a fresh viscous lsd. I am 100% sure that it was a fresh r33 viscous, because it was on a friend's car (definitely wasn't a mechanical aftermarket). He had it replaced by warranty when his diff died. It was actually quite tight and quite nice. e.g. if you give it a bit more gas when going around a corner, you could feel it go lock lock lock lock lock (sorta like a mech diff, but nowhere near as tight or as brutal).
Now, my A-lsd seems to be quite comfortable, and not what i'd expect of on a vspec, considering it is suppoed to be better than the normal gtr which did come witha mech diff. I seem to have to give it quite a bit when going in a tight circle before the slip light comes on. it deosn't really seem to lock that much either.
Now, I have changed the diff oil to new oil. didn't really do much.
My next thought was that maybe the fluid in the cylinder needed changing. It's strange. My jap owner seems to have tried to top it up with ATF. But the ATF is just sitting on top of the orignal fluid. The ATF looks quite obviously red. The other fluid looks black. So i'm not sure what eh orginal fluid is. Is it attessa fluid?
Do you know how to change the fluid? like do you have anythign on it?
I have the r33 engine manual and the r32gtr full car manual, and neither have it.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137773
I'm fairly certain it is ATF you use in there. By saying that the fluid you have placed on top sits on top of your black fluid, says to me that you are most likely in need of a complete flush.
As for the A-lsd being lazy, well it will only lock when it needs to.
A tight new viscous lsd will work when the vanes in the lsd casing are working correctly and are locking both wheels when it is needed.
The A-lsd works in conjunction with your ABS wheel sensors and the A-lsd computer works out when one wheel is spinning more than it should be compared to the other wheel and vehicle speed (as is to my knowledge) and locks the diff where necessary.
You said that you have to give it quite a bit while going in a tight circle before the slip light comes on. Well it seems like its working properly then, as ideally when turning, especially on tight corners, you want your car to behave like it has an open diff (read: a-lsd not locked), and as soon as you give it too much, or one wheel looses traction both wheels should lock, which sounds like what is happening with you?
And again, with you saying it doesn't seem to lock that much, well it all comes down to driving style I guess? And various other factors like weather, suspension and tyres.
If you say its not locking much when you're flogging the car everywhere, then that may be a problem, but as far as everyday driving goes, you should almost probably never see that slip light come on.
Mainly during spirited driving, or maybe if you take a corner too hard and go into some oversteer, or your exiting a round about in the wet and give it too much gas. These are the times you'd expect the diff to lock and it'd be doing its job.
If you're still unhappy with how the a-lsd is performing after a fluid change, i'd get it checked out by someone who specialises in their operating parameters (not easy).
As for information on changing the fluid, i'm sorry I don't have anything, i've only got the engine manual myself which doesn't seem to have the info.
You might want to check out the downloads from these guys, they'll probably have it, but they charge: http://www.jpnz.co.nz/
Goodluck
Edited by insu
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137954
I had my ActiveLSD fluid changed this week. My normal mechanic done it and im pretty sure its the same as any other LSD fluid change. He didnt mention anything extra special and knew it was a vspec diff.
The ALSD or Vspec diff isnt a hard locker diff, like a mechanical one.
Once engaged (slip is on) its a much more responsive and snap lock.
It's not like a mech clamp lock and it wont ever do rerp rerp rerp when turning corners like a mech diff does.
If I'm cornering hard and I see slip come on, I usually don't feel any difference in the car. This is the computer sorting out the splitting in real time to prevent that exact, rerp rerp rerp from a mechanical diff.
The Vspec or ALSD is basically a mech lock diff without the nasties associated with a mech lock, such as the rerp rerp repr or crabwalk affect.
I didnt have any problems with my ALSD system or fluid but since Ive applied the PowerFC patch/fix its been working 100% more so Ive sinced organised a fluid change as its on 140 on the ODO so I thought it was time for change of fluid. Other than that it absolutely rawks.
Also I dont believe this was an option for ER34 skylines. I think it was only for R33 GTST known as the GST25TML spec
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138047
Paul, I'm not sure if we're talking about changing the same fluid. I changed the diff fluid, i.e. the drain bolt on the bottom and fill plug on the side.
The old fluid wasn't really dirty. I put in motul lsd oil. this is just used to lubricate the diff.
What i'm unsure about how to change, is the oil in that tank in the boot. This is part of a separate system. this system has an oil pump, which pumps fluid to make the diff lock I bleieve?
The original fluid appears to be black. The jap owner topped it up with some ATF, which is red and just floating on top making me believe the proper stuff is something different.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138062
Unfortunately, i'm not in melbourne, but thanks so much for all the advice.
I guess i was expecting it to be different. Everyone seems to say a tight tight mechanical diff is the goods. I was just thinking that if even my friend's brand new standard viscious does that chirp chirp (crabwalk) thing slightly, i was thinking that this might.
But now i understand. I suppose the best way to think about it is like ABS. Obviously the wheels aren't going to do a full lock like a non abs car.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138065
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
