If u had a completly stock car. what would be the 1st 3 things u would do to the car (within 5k limit).
mine would be the following
Looks = Body, New paint, Sound system(still kinda looks lol)
Performance = exhaust, FMIC, power FC
https://www.sau.com.au/forums/topic/115541-what-are-your-top-3-mods/
  • Replies 63
don't know whether you can ever have too good brakes... could vary from just pads, to rotors,calipers and braided lines... - i think a really good set of pads should very much be something up there with initial mods...
full exhaust
suspesion
boost controler
wouldnt even bother upgrading brakes, factory are fine for what u would be chasing with 5k
by brakes i mean
braided lines
good pads
good fluid
and maybe slotted rotors
IMO
Turbo-Back Exhaust ~$1500
PowerFC & Tune ~$1500
Suspension ~$2000
This is providing a good condition stock motor and a good set of tyres. Prices could vary alot with even these items and it would be pretty easy to get a few trick mods done within the budget aswell.
Being a tad more realistic. Good tool kit, jack, and stands. $500 should easy cover it.
Not knowing what the car is but assuming its a turbo...
Stereo, at least a head-deck if the orginal is a bit RS. But I could EASY spend $10k on a car stereo and justify the cost.
Brakes as mentioned, just the normal if the lines are fine just the fliud pads etc. Say a good $1.5-2k there if your paying for labour. Maybe $1k if your lucky getting stuff on the cheap and do the stuff yourself.
Suspension. Probably worth while doing all bushes to be safe anyway, new suspension coils and shocks, sway bars, blah blah blah then install and a proper wheel alinement... $2-3k quite easy.
Then with the $50-400 you have left depending on how much you spent on your head deck... You could get a better filter, and or a bleed valve, and maybe someones cheap 2nd hand exaust, maybe...
You need to learn how to drive the wheels off the car before getting more power, if you dont know the car more power is pointless.
If I had 5k and a stock car..
I'd ditch the stock air box, and replace it with cone filters.
Buy a good turbo back exhaust
Buy a wideband
Buy a remappable ECU (AEM EMS, or a PFC)
Spend a long time researching how to tune the above ECU.
Buy a boost controller
And then some dyno time, and tune it yourself.
I know its more than 3 things, but its 5k's worth.
Ben
I was adding up a mods list last night and it came in under $5K
K&N panel in stock airbox - $100 - here
3" turbo back exhaust - $700 - here
Turbotech manual boost controller - $40 - here
Boost gauge - $40 - any auto store
Generic FMIC - $100 - here
Piping kit - $230 - here
Fuel pump - $180 - here
PowerFC w/ controller - $950 - here
Tune - $600
Total so far: $2940
Clutch $320 here + $300 fitting unless you can DIY.
Front and rear stabiliser bars - $460 - here
DBA rotors - $450 - here
Pads - ~$100
Total: $4570
Most of those prices include delivery,. The parts listed are all pretty easy to fit if you have a decent set of tools.
Thats $5K for a car that will produce ~200rwkw and turn and stop reliably.
I presume you liked the look of your car to begin with or you wouldn't have bought it, so why not leave it that way and avoid unwanted attention. And as far as the stereo goes, I'd rather listen to my car most days.
edit: throw in a HICAS lock bar from GTRgeoff and a set of pinepples to use up the remainder (bad maths skills):(
Pineapples - $60 here
HICAS lock - $150 - here
revised total $4780 :D
Edited by Lazy-Bastard
Generic FMIC - $400 - here
Tune - $600
Total so far: $3240
Pads - ~$100
Total: $4870
Most of those prices include delivery,. The parts listed are all pretty easy to fit if you have a decent set of tools, so we'll soak up the remaining $130 in hardware along the way :D
edit: throw in a HICAS lock bar from GTRgeoff and a set of pinepples to use up the remainder :D
....i went $80 over budget ;)
$80! :( Not good enough! jks
That seems to be the best cost analysis so far! Im down with it!
A lot of people will not like it because there aren't any brand names involved, so they can triple the price and get the same performance. Oh, and pay someone else to do all the work and learn absolutely nothing about their car along the way :D
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
