Hi all,
Been reading alot about this forum, only got a chance to register now.
Sorry to ask questions in my first post but I'm running out of ideas. Here's my problem. I took the cam sensor (the thing on the cam gears cover) out to check my timing belt then put it back ( I think I turned a few turns of the thing-stupid me) the car wouldnt want to start, no matter how I adjusted it it just won't start. Can anyone shed some light? Thanks heaps...
https://www.sau.com.au/forums/topic/115606-cam-sensor/
Did you move the timing belt at all?
If you didn't the cam sensor has a half moon thing inside the gear that goes into the cam. Make sure its in position and on properly. Adjust to the former position and make sure the cam wiring is in place.
If it dosen't start, try using a timing light to see if your out.
https://www.sau.com.au/forums/topic/115606-cam-sensor/#findComment-2127966
I didn't move the timing belt at all. I've just found out that the half moon key on the cam was broken thats why I can slide the sensor in more than one way. How the hell am i gonna get it right? I've tried many angle but it wont start still. I'm thinking of getting another exhaust cam. Any idea how much the stock exhaust cam is going for?
https://www.sau.com.au/forums/topic/115606-cam-sensor/#findComment-2137889
There is a way to do this but will take some time. I can think of 2 ways atm:
1. unbolt the CAS so it can freely move clockwise & anti-clockwise. Get some to crank the car and keep moving it clockwise until it wants to start and if not anti clockwise. If it hasen't started note how much you were able to move the CAS and re-position the CAS in the cam and try again. If you find the point where she starts, move the CAS from the cam until you are able to bolt it up and have some movment.
2. Use a timing light while cranking and see if the marks show up. If not, not the CAS from the crank until the marks up, means your geting very close. This method can also aid the above method.
Just a note, when engine is at TDC (top dead centre) while removing the CAS from the cam, there is a geogon pin that goes through the shaft of the CAS. This pin should be facing directly up or down - one of them will be right. This is good as a starting reference.
Its a bit of messing around but a little time & you'll get it.
There might be a better method, this is just what I have done before.
https://www.sau.com.au/forums/topic/115606-cam-sensor/#findComment-2138149
Firstly, visualise where the CAS needs to be to align if the half-moon key was still attached to the cam.
Alternately, the CAS also aligns via a set of teeth on the CAS shaft and the cam, and the engine will only start with the CAS in one position. Simply move the CAS shaft by one tooth and try to start the engine. Once the engine starts, use a timing light to set the timing correctly.
https://www.sau.com.au/forums/topic/115606-cam-sensor/#findComment-2138840
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
