would be a bit difficult getting 50 cars up and around a cul-de-sac
it would be fun though watching :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
yeah i dont know that area too well, being from the hills, but If you wanted to make it longer what about starting in say vic park then going along riverside drive then onto mounts bay rd then follow that to cottesloe then back up westcoast hwy in the hillaries direction?
just an idea
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
