Hi Ladies,
After many requests, I have finally organised something I hope most of you will be happy with.
SAU Vic's 1st Girls Night Out
When: Wed 7 June
Time: 6pm - 9pm (we can carry on if we decide)
Where: BARCODE @ Crown Casino
Please see attached for further details.
Please feel free to bring your friends/ sister/ cousin/ mum/ netball team/ whoever!!!
This night will be a great social night to get all the SAU girls together for a little bonding without the boys and car talk.
Hope to see you all there.
Cheers
BEC
PS. All you boys out there reading this - please print off the attached PDF and pass onto your lady.
Also attached a bad quality scanned version as a couple of you couldnt open the 1st one. :thumbsup:
GirlsNightOut_Flyer_A5_webversion_copy.pdf
GirlsNightOut_ScannedVersion.PDF
https://www.sau.com.au/forums/topic/115832-girls-night-out-wed-7-june/
  • Replies 49
if any of you need transport let me know, as i am unable to attend i will be sober as a judge so happy to play taxi. given you guys always drive me around most of them time when im on a booze cruise
one night when we were pissed and they had mc's there, wanting ideas for something to do and paul went up to them and said simpsons trivia!
and they liked the idea so started asking questions about it - they thought it was a bit suss that the guy who told them to do simpsons trivia was standing next to the chick that was getting all the asnwers!!!
:O
Ahhhh - I got the Simpsons Trivia Game (to be honest it was a great idea, but the game is kind ghey).
Oh yeah and Troy and Brisby - if you 2 dress up as girls (wigs and dresses are a must) and actually get let in - for sure you can join us. :O
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
