Hi Guys - Thought I would put it all in one post -
I have for sale
R32 GTR ABS UNIT - its a bit dusty - but Was working fine when removed.
$SOLD
(FYI these are over $4000 from nissan)
(Pics Soon)
1 used Blitz Blow of valve with RB20/25 Adaptor
$SOLD
Buddy Club P1 Wheel. 17x8 +22 5x114.3 Hypergold. Almost new - but has a scratch on one spoke.
$SOLD
Greddy Profec B Boost controller. Good working order - holds boost nicely (even at 1.5 bar :wave: )
comes with EVERYTHING + english instructions.
$SOLD
email me [email protected] or PM
Kind regards
Steve
Edited by Antimatter
https://www.sau.com.au/forums/topic/115948-r32-gtr-abs-unit/
Bump
I also have for sale
genuine and Good working order
$180
Can send anywhere
Pics soon if I dont sell prior
[email protected]
Icydude - sorry - no, But I would suggest it would be best to rebuild it anyway. All I can say is it was not slipping when it was removed.
Musky - I will try to get some pics up on the weekend
JNJ - sorry - have no need for a bumper and wing (at this stage :/ )
CJlancer - pics soon - located in melbourne
Thanks!
Sorry - dont want to separate - you could always buy the whole thing and just sell off the BOV yourself :/
would u sell the blitz adapter off the blow off valve seperate? if so let me know how much
I have for sale
1 used HKS SSQV Blow of valve with RB20/25 adaptor
(both genuine and good working order)
$170ea
RB26 TURBO DUMP PIPES - HKS STYLE - BRAND NEW inc GASKETS
$200pair
Nismo/Exedy Twin plate clutch (push type) from 1990 GTR. USED -Was not slipping when removed - comes with lightweight flywheel.
$200ono
$150ono
Greddy Profec B Boost controller. Good working order - holds boost nicely (even at 1.5 bar :P )
$290
HKS Super Power Flow intake kit for R32 GTR - EXCELLENT CONDITION - All clamps, hoses, brackets and adaptors included
$200ono
Kind regards
Steve
Hi Steve,
Im interested in the clutch assy you have for sale, im on the Gold Coast, so was wondering how much inc freight to get it here ?
Cheers. Jay
Steve, can I come take a look at the dump pipes? I have plenty of time on my hands so anytime during the day.
At this stage I'll take them if you are willing to hold.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
