I'm currently running a Tomei RB28 with A'pexi V-Max 270/11.4 cams and top-mount twin externally-gated HKS GT2835s with 0.61 A/R exhaust housings.
One of the turbos has killed its bearing cartridge and I'm interested to know what the current options are as to bolt-on replacements, before I spend more on going for a single ...
I'd like to keep the reasonable response of my current small-A/R 2835s but with more power (looking for ~750 bhp at the flywheel) - any suggestions?
Thanks,
Phil
Edited by Philip
https://www.sau.com.au/forums/topic/115952-hks-gt2835-alternatives/
2835-R's i think are a step up from then normal 2835
i've been in a car RB26/2835R's (RWD 32-t) and ive never been giddy like i was the day i got out of it.
Alternatively, the t04z is the way of the future :O
Thanks - I can probably source some more HKS GT2835s, but was wondering if there were any newer generic Garretts or similar available that came recommended.
If I was going single, T04Z, GT4077R etc. would be high on the list.
Phil
Yes there are some options . Brett at GCG rebuilds the GT BB range so if its just the bearing cartridge should not be to difficult . If the wheels have rubbed on the housings it may be a different story .
Garrett do a turbo they call the GT3071R "WG" for wastegated and it I think uses a similar cartridge to the GT2835R depending on which turbine and compressor trims your 2835R's have . If you can give me the numbers off the turbos ID plate (should be something like 700177-00XX or -50XX) I'll check it out .
Brett sells some of the HKS range of unique turbine housings so he may have or be able to get the next size up of turbine housing which from memory would be .73AR in T28 flange .
The listings for GT2835R I have are .
CHRA No 700177-0002 , -0003 , -0004 and -0001 I suspect is another possibly 48 comp trim variant .
The unit numbers I have are 700382-2 , 3 , 4 , 6 , 7 , 18 , 19 , 20 , 21 and -24 .
If that -1 CHRA is a 2835 its unit no is 700177-0001 or -5001 .
Hope this helps cheers A .
Yes the "R" variant has the larger 90 trim turbine and 56 trim compressor . The std 2835 uses an 84 trim turbine and 52 trim compressor .
Just on the "R" prefix , I always tack it onto the end of Garrett GT BB turbos because it usually means rolling element centre section .
Cheers A .
  • 3 weeks later...
Great information - thanks very much.
The cartridge number on mine (48 trim compressor) is 700177-0001. I'm going to go for the 52 trim compressor assuming I can get the larger 0.75 or 0.87 A/R exhaust housing somewhere in the UK.
Phil
Yes the turbine housings from HKS would be .73 and .87 AR ratio .
Always remember that going up in housing AR increases the gas flow ability at the expense of gas speed . I would be wary of going too big because you are basically doubling the difference with two turbos . Any increase in turbine housing AR and compressor trim will make them come on boost later that what you have now .
I would be doing the sums on the cost of a pair of HKS GT2835's vs either a HKS TO4Z or a Garrett GT4088R or Precisions hybrid GT4067R . Actually I'd Email Geoff Raicer from Full Race .com in the US as he's had lots to do with the GT4088R and GT4067R . Arguably you can probably make the power with good response and low turbine inlet pressure if you get the manifold and turbine housing AR spot on . Geoff has used twin external gates on split pulse manifolds for single turbo engines so maybe you can re use yours . In Americanlish twins may look "bling" but the modern single is hard to beat from a weight and complexity point of view and costs often a lot less .
OMG the twin turbo terrorists are in coming , bye - ducks ...
I would go the GT40 single route without question if I was starting afresh, but there's the expense of turbo, manifold, downpipe, inlet, oil and water lines etc. to consider; whereas I just need some new cores and maybe exhaust housings to get going with what I have.
It seems that the 0.61 exhaust housings might have been too small in any case (RB26 kit usually comes with 0.87 A/R) - only just over 500 at the hubs at 1.6 bar on a Tomei 2.8 bottom end and A'pexi V-Max 270/11.4 cams ...
Phil
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
