Hi,
does anyone have a highflowed rb25det turbo from sliding performance? are they reliable? what sort of setups do they offer and is the business reputable?
Direct Bolt On High Flowed Turbo's for RB25DET from $890
http://www.slidingperformance.com/catalog/...products_id=262
How do i get in contact with this company?
  • Replies 264
Posted Images
I can't speak more highly about the turbo Aaron had made me... admittedly my one is a little bit "different" to his other items but it is based on the same theories.
I'm making 200rwkw with 10-11psi (boost drops off due to other issue) which is at the absolute limit of my ECU after tuning at Hitman.
Lag is minimal, the turbo sound is orgasmic and yes I'm very very happy with what I got. Aaron is a top guy, he'll answer any of your questions and will ensure you "learn" something from it rather than just buy something from him.
In a few weeks I will be able to boost the thing into it's efficiency range of 18-22psi, should be very interesting to see what happens then!
My 2c
Dyno Graph is on my website... follow the link below.
Links; he doesn't want to use your turbo :O It's not good enough, he replaces it with a "new" item!
PM me for more details if you want, Northern Beaches Performance has a few deals going on with Sliding Performance at the moment.
Journal Bearings
Steel Wheels
You KEEP your turbo!
Sorry, need to ask Aaron about the flow rates... but I'd assume it's large considering I could boost to 13psi on my standard turbo but only manage 11psi on this one before the standard ECU starts to play dumb.
Links; he doesn't want to use your turbo It's not good enough, he replaces it with a "new" item! Bastard :O..
Hmm.. so flog off mine for 300.. pay for some of the intercooler.. hmm.. not bad.. not bad.. get an aftermarket ECU.. good $2500 upgrade + labour + tuning..
sorry to go a little OT, but did hitman tune your stock ECU? how did you find it? and why is it now at the limit of the ecu?
i didnt even know he did re-maps, i may take in the GTST.
BB - Hitman didn't tune my stock ECU - he tuned the SAFC2 which is in my car. The stock ECU has a lot of operating parameters as we all know - we couldn't wind up boost past 11psi as the car would cut out at 4.5K rpm.
Anyways, new ECU going in soon along with 2 more tunes so I'm going to be a happy boy!
Everyone else:
NBP is now the reccomended Sydney installer for all of Sliding Performance's Sydney turbo sales. Currently the arrangement is: buy a turbo from Aaron, add another $330 to get it installed (fluids included)
Journal Bearings are bush bearings.... not ball bearing.
Proven results are on my website - look in the Tuning Results section! Sorry for the lack of updates on that thing, haven't had time.
Modifications list has grown heaps since then too :) Even without the stuff that WILL be going in and a re-tune I'm on about 220rwkw at the moment but it's running REALLY REALLY RICH!
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
    • Do you know what size restrictor? Just flushed it with the Prestone flush & then water numerous times until the water ran clear, still looks rusted & will no doubt cause trouble later.
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
