Sorry i havn't sent out the "official" PM yet just been a bit slack, trying to find a new Power Supply for my comp, buy a new copy of BF2 and organise my ADSL2 and work and assignments.
Will DEFFINATELY do it tonight so i can edit this thread to show the numbers as of 2night about who is in.
Shaping up to be a good battle though guys!
  • Replies 146
Posted Images
that is very hospitible .. ty .. only 1 problem can the server handle the xtra bandwidth more players would use ... no 1 wants a lag fest
why dont u just use ur orriginal copy of BF2 to run on ur NEW comp and buy a new copy of BF2 later for when ur mates come over and u want to lan it up in the same server hence needing the 2nd CD key
i will be in hardly play BF2 any more seems that every1 is a whore @ sumthing in that game
same as tangles i will be ready to play after 7:30 when i put my daughter to bed
we should try and organise a vents for that night too imo most u guys are familular with voice comms
Server = Telehoused...
ah i see
if its hosted from a OGN or Mcgoo services then it wouldnt have 100mbit to itself but would be shared resourses but should be a good box
or is it hosted @ Host Excellence - which i add look like you have great data packages @ a reasonable price
even if its hosted by your company its shareing resources with your paid hosts which i imagine there not takeing up alot of bandwidth
ah i see
Not sure on that one, but im sure it is shared resources. The thing is probley hosted in the datacenter where i work so i would have plent of bandwidth at its disposal.
Its not hosted with Host Excellence. Yes we do have very reasonable prices and data limits/quotas - drop me an email if you need some hosting - msanders (at) hostexcellence.com.au
All in all, enough ranting for me. The server is up as anthos said, it has good resources and we (me and anth) are looking foward to playing some games with the fellow sau'ers soon.
-SiNDOWS
-SiNDOWS
yes sorry i tend to go on the technical side a bit sumtimes :)
do the rest of the states know about this little BF2 get together i think we should wear a SAU|SA, SAU|NSW and so on type prefix too our names
depending on how this goes once a month have a SAU get together
fun will be had by all
So after all of that, i think the plan is as follows:
Sunday 21st
Clan Server BF2 IP: 202.60.83.12
Port: 16567
Password: none (There will be a password on the day of the battle to keep out Pub Server crawlers)
How does 9pm sound for everyone?
BTW my username = Johnny.Funpants
Have i got it right?
Keep us notified, when you're ready hey! :sorcerer:
and yes that sniper gun is pretty accurate. lol
but Im too much of a Rambo-support freak, mow down 5 on the barrell roll and then yell out "get your ammo here, Ammo!"
:nyaanyaa:
Edited by Tangles
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
