  • Replies 191
Posted Images
yeh i rkn, as it stand im about 5 mins from KK, so stop bitching, its great where it is. any ideas on how long the lines are for this joint now? i wanna go down there but not wait in line for 3 months to get sum, well i would but i dont have the time right now...
Great for u but far for others,has anyone actually been through the drive through yet :ermm:
Waited in drive thru for 1.5 hrs and finially got my 3 boxes. Ate about 6 at once and feel sick.
Wont have a need for more for a few weeks again i recon
hahaha yeah thats pretty much what i did too... i wont be going back again until i can actually walk straight into the door and try their milkshakes and stuff and actually sit down.
tried monday night bout 10ish. the line was out passed the roundabout, down towards bunnings, so we just ditched n went to glenny n ate at a cafe there. i know everyone says they're good but damn, i aint waitin in line for hours for sum donuts
missing out :teehee:
Just waited 2hours and 23 minutes for these things. Never again
i thought i might get some donuts on the way home from the cruise on friday night
it was 2.15am and i drove past and shook my head drive was packed 50 cars easy
Oh and i forgot to say.
When i was there this guy was almost right at the door. Then for some reason security kicked him out lol. He looked a bit like a f*ktard and so did his friends (with eyepatches n shit).
Hahaha waited that long and then bye bye!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
