  • Replies 101
Posted Images
Well seems we have had a major setback. Liz has not made it. Maximum entries being 60 with 5 reserves. You must be very pissed off at the moment Liz. This grumpy old bastard will be counting the entrys and If the roster isn't full I WILL BE HAVING WORDS.
I still have to go on sunday so what about 1.00pm at that car park?. Jas post me your mobile and I'll ring you when we get close.
Neil.
Even more pissed now that I've cancelled the arrangements I had to get my car fixed before next weekend because of their decision... then this morning, I get an email from the event secretary saying he's changed his mind due to lack of entries.... GRRRR
Damn WSCC saying I wasn't a champion, I mean, sif I'm not a champion!!!! I think they actually found out I was a champion hence the sucking up now! hahaah
I'll still be heading down to watch as I'm keen to get into these hillclimb thingys!
so they said you not in, you cancelled car repair, then they rang to say you are in? good job. oh well, there is always the next one! plus are you coming to oran park on 29th?
yeah a bit frustrating!
nope ;) not fair on the boss to ask for time off work right now... I'm settling for the Luff day on the Sat after it's not full circuit but it's better than nothing!!!
I'm going to try and get to a McGill track day sometime soon, big mcgill fan i am!!!
oh man, I just saw a video of the hillclimb... stuff it.. I'm keeping my entry and if I manage the get the car working during the week, I'll be there with bells on!!!!
The silver car going up one?
Did i email that to you?
You all so want a Peugeot after seeing that 60 year old Panel Van.
Jas I did try ringing you but I must have typed your number wrong cause I got someone else.
Liz the great, thats the spirit girl.
I'll have to check the vid when I get home,,,crapbox thing here is as good as the cars we sell,,,bloody euro-trash.
Neil.
Neil.
Neil i pmed it too you!
and :no: to those peugeots haha i could not stop laughing..
Neil - Corinne has a video with you in it
Im so buying a Pug tomorrow, i just found some change on the floor so maybe ill buy 2?
yea it was sent.. :)
Which vid is that? Got a link or something?
I posted a link to the NSCC's gallery here earlier. A pewter S15 with a roof-mount camera doing the run as well. Wouldn't mind seeing some other cars doing it.
I have a vid of a NA S13 doing it in the wet floating around somewhere as well.....
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
