The pipe that goes from the cooler to the throttle its got a 1cm diameter smaller hose connected to the side of it that goes to a t-junction and then i dunno where. Its neart the pwr steering liquid.
My question is this: on the piping kit i got there is no hole there for that hose to go into. Does any1 know what that little hose is and do i have to connect it to the new piping?
Thanx guys,
ur help will be GREATLY appreciated
Thanx guys,
1cm smaller than the cooler pipe? or do u mean a 1cm diameter hose, like a vaccum line? maybe for a guage if its a vaccum line? did u get a set of instructions with the cooler kit, and what cooler kit u got/whered u get it from? if its specific for ur car, it may have a mention for it. from my understanding, the line was there previously, it didnt come with the cooler kit...
Edited by VB-
i mean a 1cm in diameter hose like a vacuum line as u said. I don't have any afta market gauges. I got the piping from hypergear and it doesn't have instructions, its specific for my car.
Yea the line was on the stock pipe but there is no hole in the new pipes to allow for this line.
probably u best bet would be to chase the vaccum lines, and see where they go to. if its before the throttle body, its probly not a guage, but it's probly there for a reason. it may not be necessary, but find out where the line runs to, or wait for sumone whose done a cooler on the same car
Don't know if it's too late, but with my kit I got a t-piece & a hose about 3ft long, just get someone who know's about this to show you what line to cut, whack in the t-piece & run it back. The pic shows where mine ran from which is what you're asking about. I think the line in question is something to do with the factory boost controller.
For the record this is when my car didn't have 350rwhp. :P
So basically, u run this little hose to another hose and connect it via t-piece.
Question is what hose u run it to?
any vacuum line off the intake piping there is one to the charcol canister
Thanx dude,
Just to clarify is is better to put it to the hose that connects to ur boost gauge?
Or better to put to the holse that connects to BOV/actuator?
For the record this is when my car didn't have 350rwhp. :(
Hey with the pipe that goes past/near the timing belt, did u have to cut the fan a little?
cut the fan ,took about 10mm off mine. Take off the whole fan to do it, i used a jigsaw. do one blade then use the offcut as a template to mark the rest. I used some sandpaper to clean up the edges. good luck wit it.......
Thanx for the advice much appreciated it. Me and my friend basically mounted it so it wouldn't touch but it seems a little dodgy and it still moves around a bit. I might take ur advice and just cut the fan. Thanx again
Progress report:
Sat night: 9pm - 2am.
At my mates house, my mate ditches me so he can spend time with his g/f. So being a absolute N00b, takes me 5 hours to remove bodykit, front bar, stock piping and stock cooler. My mate did however manage to drill out a screw i happend to shred.
Sun
Even tho my mate said he would be up at 9am to help, he gets up at 11 then goes straight to work. Oh well at least i get to use his tools.
My other mate with a 180 comes around and we manage to mount the cooler and with the help of another guy that was walking past in the street, manage to get all the piping done on the hot side.
We had to use some pvc since the alluminium piping i got didnt quite fit in place. It was difficult to get rubber/silicon on this PVC.
Also as mentioned in the post above, half the cold side piping is done, altho in a dodgy fashion as to prevent the piping hitting the radiator fan.
Tommorrow
Finish uni at 5
Will have to finish cold side pipe, ie drill a hole in the chasis to fit the cold pipe from the intercooler to the adjoining piece.
Also will have to decide where to put my horn and also where to connect the loose vacuum hose to.
Hopefully this all will be done by the end of Monday, thus i will be able to drive my car
You used PVC....OMG...
Please stop there and take it to someone who knows that the f**k they are doing...
ease up!
there was a topic on the use of pvc as intercooler piping and the people who have tried it said that it worked just fine. even if it aint as pretty as shiney sparkely aluminium.
dont get on his back just for that, eh?
its a bit harsh.
Progress report:
LOL!!!! this is sounding like proper bush mechanic!!! good luck!!!!
LOL, u guys are funny. I fixed it up so that the pipe so it mounts properly, and doesnt look dodgy. I snipped the fan blades so it fits now.
Tomorrow or Wednesday i goto:
1) drill hole on driver's side and connect the cold pipe. estimated time: 1.5hrs
2) rellocate the horns somewhere (any good ideas?) estimated time: 0.5hrs
3) Trim the front bumber bar and put it back on estimated time: 2hrs
4) Connect the stock boost controller back to the BOV hose and t-piece it estimated time: 0.5hrs
5) Put front bodykit back on estimated time: 0.5hrs
6) Goto the guy who i bought the kit off and abuse him for giving me the wrong size hot pipe. (this is where i had to use the pvc)
7) Get a refund for hose from that guy since he gave me the wrong sizes and i had to buy my own
estimated time: 0.5hrs (due to arguments)
8) Possibly remount the cooler off the bumper bar (atm it is mounted from the chasis bar running along the top)
Oh yea, all these time could be halved if my mate helped me instead of spending every fricken second wit his g/f.
Pics will be up soon guys, hang in there for me
Edited by Taso84
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
