Look closely, it is a measurement of tractive force only - the unit is Newtons, not Newton Metres.
Depends how the software is calibrated what you get.
Main thing is to check the shape of the graph for the before and after , and also whether you get dips, if the graph ramps like a ski jump, tapers quickly etc.
cheers
Dale
https://www.sau.com.au/forums/topic/116669-torque-reading/#findComment-2145796
what mods have u got? the torque is jumpy lots. how did it appear on the dyno when you watched it? did it look like it was slipping around a lot?
Hi flowed std turbo, SARD 650cc inj., SARD fuel pump, fmic, LINK ecu.
It's a R33 SII by the way.
I didn't get to see it unfortunately, had to be at work, so can't tell you if it was slipping around or not.
Edited by b.
https://www.sau.com.au/forums/topic/116669-torque-reading/#findComment-2145902
So how can I find out how much torque my car makes?
TE(Tractive effort) is the actual torque delivered to the dyno rollers. Actual engine torque T = TE x r / GR. Where r is the radius of the tyre and GR is the final gear ratio. Therefore if the run was done in fourth the GR is 1:1 but the diff ratio is 4.11 in GTST. So say for 17" tyres with 45mm profile. T = [5000(from graph) * ((17/2 *25.4/1000)+(45/1000))] / 4.11 = 317 N.m at the flywheel.
https://www.sau.com.au/forums/topic/116669-torque-reading/#findComment-2145910
Wow! you make it look easy. Spot on with the tyres too!
Cheers mate thanks for the help.
https://www.sau.com.au/forums/topic/116669-torque-reading/#findComment-2145923
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
