Hey all, I am relatively new to the Skyline & turbo scene (usually found playing with V8 Commodores) - but I have just bought a nice black R33 GTS-T - 1996 model. I just a couple of qustions about them:
1. How much boost does a GTS-T run standard? I don't have a boost guage so I am wondering if anyone knows off-hand.
2. How much boost is a good, safe level to increase to - maybe 12psi?
3. In the next few weeks I am looking at adding FMIC, maybe a bit more boost, and do a dyno tune. The car already has 3" turbo back exhaust & HKS pod-filter. I am hoping for around 180-200rwkw, what else do I need to do?
Thanks guys, I will post up some pics when I pick the car up next week.
Cheers.
https://www.sau.com.au/forums/topic/116685-just-bought-r33-gts-t/
Welcome to the Skyline world!
Standard boost is 7psi but I am told it is safe to run 12-13 with standard intercooler.
The output after the mods depends on the tuner, if the person knows what he is going then your output should be good on the dyno. I goto a guy in Granville Sydney.
I am going to get a few things done to mine soon. Turbo back exhaust(dump pipe) with High flow cat and a boost controller. I will run all this with standard air intake and intercooler. It won't cost me an arm and a leg but should get me up to 180rwkws.
Edited by harryg
You do have a boost guage - check the instrument cluster! It's in mm/Hg - not the standard psi or bar but it is an accurate boost guage.
You probably don't need anything else except for the FMIC and increase of boost to get 180rwkw.
Cool, so 180-200rwkw is achievable on 12psi with exhaust, intercooler and tune (assuming the tuner knows what they are doing)? Sounds good to me.
I didn't notice the boost guage on the instrument cluster, I will have a look when I pick the car up. I have a unit converter to work out the psi figure.
Thanks guys.
Edited by Quinny
10-11 you can sleep soundly at night
11-12 keeps you awake at night
12+ go to sleep knowing the fact that your turbo does not have long to live anyway
my 2c
OK, so 10 psi is a better idea, no worries. I am not as concerned about performance as I am worried about reliability. I don't want to do anything to jeopardise the reliability of the engine.
if you want 200rwkw
you will need: apexi pfc, a decent pod filter with cai, full exhaust, ex cam gear, fmic, and i duno.. 12psi and maybe a fuel pump?
dont run the turbo over 1 bar of boost "14.7psi" as the wheels are ceramic and will most likely come off and fly down your exhaust as mine did...
thats just stupid..
Ok, so it looks like I need a little more work for 200rwkw. As I said, I am more concerned with reliablity than performance, so I don't want to go too stupid.
What sort of power would you expect from 3" exhaust, filter, FMIC, 10psi, dyno tuned on standard turbo and computer?
I run 12psi but have ECU, Fmic, fuel pump and regulator plus your mods and with a good tune has 210kws, the fuel pump was my last upgrade as the standard one just didnt cut it, I haven't got after market cams and was told I wont really need them below 240kw, I know my turbo may die at this level but with careful use it has lasted 1 1/2 yrs now.
hey, i run mine on 10psi and have had no trouble, with 10psi, frontmount and no tuning i got 177kw at the wheels, so there is a good indication for ya
That is what I like to hear. I want to avoid spending too much money on the car, I have spent way too much money on cars in the last couple of years. I want to try to get the best gains I can with the basic bolt-on mods. I don't want to go to the trouble of changing the turbo, internals, upgrade the fuel system etc, I just want the best gains I can get for a basically "standard" car.
Would I be better off spending my money on a good intercooler or a Power FC computer and dyno tune? Which would give better gains for the money for a basically stock engine (10psi, exhaust & filter)?
I will be getting both at some stage, but which would be better to get first?
Edited by Quinny
FMIC by itself doesn't do anything for extra performance. It allows you to run higher boost pressure. It is also a safety-net sort of part as FMIC will make your car run better on hot days.
PowerFC will let you control air/fuel/ignition etc.
Most people will get the FMIC first but if you don't want to increase boost pressure you may want to get the PowerFC first - this will allow you to do changes like run better AFRs which will make your car perform better as well as conserve fuel in the top end.
Thanks mate, I might let a dyno run decide what to do next, if everything looks ok, then I think I will bump the boost up to 10psi, and add the FMIC, then get the computer a little later. If the tune looks out when the dyno run is done, I will get the computer and re-tune. Thanks guys. Sorry for all the questions, I am new at this....
I have just started putting a new website together still in progress but I have uploaded a R33 tuning guide which will help you and others. Read this guide and let me know what you think.R33 Tuning Guide
Cheers
PS: Please excuse the spelling :P
Edited by Munna1
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
