Hey All,
I am tossing up between 2 dump pipes..
1) BOS IMPORTING
2) CES RACING
Who here has either of these and what was the power increase after install?
BOS IMPORTING one seems better value for money, but the CES one claims very good gains..
Opinions?
Cheers :laugh:
-JD
PS: talking 33 gtst's
Edited by JD-33
https://www.sau.com.au/forums/topic/116863-dump-pipes/
I am looking at getting one myself...
This is what I have at the moment, I am guessing it is stock?
yeah pretty much stock looking. mine is like that too..
Ive decided that im gonna go for the BOS IMPORTING one (only because of all the replies to it in this thread :P ) ... haha
-JD
Will let you know how it goes
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2152163
the one my mate has is just the split dump pipe and its split for about 10-15cm. i'm just going dump only as the car came with a 3" front pipe and i can't see the point in spending $400 when i can get away with $150. if i didn't have a 3" front pipe i'd get one of the BOS ones.
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2155079
screamers are illegal and can be bloody loud.
people dont seem to worry about screamer pipes as much as say no cat .. but the penalties are the same.
you shouldn't see any difference in spool times as this split system only really come into effect once the wastegate opens, therefore it is already at full boost.
noticed on my old setup that it would rev out much cleaner after the 5-5.5K rpm range ..
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2155604
hey guys just wondering i just bought one of these split dump pipes but now i have gone for a high flowed turbo and has much more room behind the turbo in between the wastgate and the exaust . would it make a big difference if i dont have the little metal bit in between to seperate these two?
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156129
yes the little bit, or divider is half the point of a split dump. without the metal divider between the two they are still likely to cause excess backpressure.
imho a split dump without the divider is kinda pointless
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156226
i ought the split dump pipe from just jap and was told that it was for the hks turbo so i took it off and it is lost but looking at the gap on the high flowed turbo, it has plenty of room for the metal to split the pipes does anyone know when i can get just the spliter part from?
https://www.sau.com.au/forums/topic/116863-dump-pipes/#findComment-2156383
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
