hi boys and girls
i am just wondering what big hp skylines are using when it comes to automatic gearboxes.
i have got to the point where my strengthened toyota box cant handle it any more.
i am being pushed towards an al's race glide C4 or a power glide. i still drive the car on the street a fair bit but not more than 4000k's per year. with the new engine i intend to build it will make approx 900 at the crank so it has to be able to handle that sort of power.
any info would be appreciated.
https://www.sau.com.au/forums/topic/116996-automatic-trans-on-drag-cars/
hi boys and girls
KEAS.COM.AU SAY EDDY REFERED U BUSTER AND I BOTH USE 1,JPC BRESIANI,RAJB AND ALOT OF BHP CARS USE KEAS
I received the following email from Keas about a week ago:
Thanks for your enquiry. We will get back to you within 24rs to confirm order or answer your query. [email protected]
Haven't heard anything since and they don't list a phone number on their website. Guess they have far too much work to bother.
Adrian
If you are going to drive on street I wouldnt recomend a 2 speed, especially on a smaller motor with a turbo as there is no torque to get the car to moving when off stall and you will hate that around town trust me.... For that much power a c4 might be okay, keas can build you a killer jatco that will take it, personally th400 are my fav 3 speed, but you will probs have probs adapting the thing and it will cost a bit, just ring keas they will sort you out, alternatively if they are too busy try hugo's in melbourne, can build a tranny that bloke!!!
I didn't like what I heard at Keas so I ended up going to Mike at MV Automatics in Adelaide.
I honestly believe Mike is the most knowledgeable person with regard to Jatco's in Australia and discounting the engineers that designed the things right up there in the world. He gets jobs to do from all over the world (was building one for a Russian customer at the same time he was doing mine).
The only thing is, he's in adelaide.
phil cruickshank built my auto
i think pvl-747 is selling his glide its the same as mine as he isnt finishing his car pm him
hardcore have never worked on my car but they produce some nice cars
Edited by jas/slo32
Fred from Pro Trans in Southerland builds our autos. Built C4 in our Gallant, Builds a mean Powerglide also.
Should give him a bell, excellent bloke, will advise you on the best way to go.
9587 9594
hi boys and girls
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
