  • Replies 513
Posted Images
All,
If I was able to get my hands on some 17" NEW race slicks for about $200 would anyone be interested? Ckeck out my thread
http://www.skylinesaustralia.com/forums/in...howtopic=124955
Thanks
October 8 at EC. I will be putting a thread up in a day or two.
WHAT :pwned:
That's Bathurst weekend :ermm:
You are pulling my leg aren't you >_<
:D cheers :nyaanyaa:
PS. I have something that will fix that problem for you Liz
Edited by Sydneykid
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
