Someone.. can't remember who, has those registered as a business plate I think. They aren't the normal "tropical queensland" or "indy" numberplates that you can purchase through PPQ.
True... I enquired about them with PPQ about 2 years ago and it was a register plate and you would need to be given permission to use the plates design. You may create your own plate (within reason) however this will cost you a kidney...
im pretty sure Ernest from Nismo Pty Australia (formally Skyline Imports) own the NISMO plates. i have a set of Autoforce import plates which i cant sell unfortantly
Edited by 53XYN
