Hi folks,
well, it's time to replace 3rd and 4th synchros on my R32 v.spec. I had toyed with the idea of purchasing a spare
box, swapping out and selling the old one, which will most likely be the easiest option but then I don't know what I'm getting.
I've removed/replaced an R32 box before.
I have the workshop manual for the R32; but I think the box on the v.spec is a 33.
So I don't know how close the manual is to reality in terms of the internals.
So. Is reconditioning a gearbox something for an amateur to attempt? I'm reasonably good with mechanical stuff.
I'm also happy to pay my local guy to do it (anyone have any estimates on time for a professional to disassemble
and reassemble); but I wanted to actually learn something.
The floor is open...
Saliya
https://www.sau.com.au/forums/topic/117414-r32-vspec-gearbox-recondition/
Not sure on how easy/hard it is, but just thought I would mention that you can no longer buy new parts for these gearboxes. If you want to recondition it with brand new Nissan stuff you will need to upgrade all the synchro gear to the R33 GTR Series 3 stuff, which is all Nissan sell for the 5 speed now. Adds up to be quite a costly exercise.
Hmm.
OK, so I've pulled the box, but gotten professional help to pull it apart and show me what bits
are what; and what goes where. Very informative experience, and very much appreciate the
time taken by the workshop to show me the ins and outs.
Just as an update because of what Amaru has added: synchros, bearings, and gaskets for this
box are all still available from Nissan Australia or (in the case of bearings) the supplier
of your choice. This information is current as of the now, of course :D but apparently the
box is very similar to a newer Navara gearbox so I'm hoping that these wearing-out parts
will continue to be available for awhile.
Other parts in the box - gears, sleeves, shafts - may or may not be available. I tried to get
a 3rd-4th sleeve and was told by Nissan that I had to buy new countershaft, new 1st-3rd gears,
new 1st-3rd synchros - a grand total of around $2k. I think this is what Amaru is talking about.
Thanks, Nissan, but no thanks. I think if it comes to that I'll be talking with PAR sooner than I
had budgeted for :P
Regards,
Saliya
of your choice. This information is current as of the now, of course :O but apparently the
had budgeted for :O
You've contradicted yourself a little between the first and 2nd para's. Bearings and gaskets are certainly available, but synchros for any GTR gearbox built before about 1997 require fitting a bunch of other 'update' parts including gears, coupling rings, sleeves, etc, etc....for 3rd and 4th gears alone this ends up costing around $2K just for the parts. I found this out around 2 years ago when I re-built an R32 GTR gearbox. I know the Nissan parts people fairly well, and at the time I had them chase this right through Nissan in Japan. That said, from time-to-time I still see people on this forum claim to have got their GTR gearbox rebuilt with new synchros. I'd really like to know where they got the parts, but I suspec they might not be getting all that they paid for.
Hi,
SteveL,
No I haven't - I said that if I wanted a new 3rd-4th sleeve, I had to do a (roughly) $2k rebuild,
because a new original sleeve requires the fitment of a whole bunch of other parts.
You've contradicted me, at this point :( I'm saying you don't need updated internals for new
synchros, you're saying they are required.
To be honest I don't have the synchros in front of me right now; but I'm hoping to have them
in front of me on Monday. Since it's so contentious, I'll post the results as they come in.
When I ordered the parts on Friday, I paid under $400 for 3 synchros and a gasket set. I was told
that the parts were in stock and would be shipped on Friday, and that they would fit my car.
If I get synchros that don't fit; or a backpaddling story from Nissan, rest assured
you guys will be the first to know. But at this stage there's light at the end of the tunnel for us
GTR owners that have worn parts. Hopefully the light isn't an oncoming train :)
Bl4cK32,
I need new bearings for a r33 series 1 box. Do these run the same bearings as the GTR's?
Do you guys know if i can get an aftermarket set of bearings, from say cbc, that will work in my gb?
No idea. A new bearing 'set' (ha! there's no such thing) for my box for the commonly
replaced bearings is $600ish from Nissan, and under $200 from my local transmission guys.
You should be able to replace most if not all bearings with identical or better aftermarket parts,
and for less money,if that's any guide. You need to talk to a bearing expert :ermm:
Regards,
Saliya
Yer i have talked to cbc, and they said they can match anything i bring in, but i wanted to buy the bearings before i get the box pulled apart, incase something goes wrong....
They dont have any listings for rb25, or rb26 boxes unfortunatly here in SA, just rb20 as its roughly the same as the vl box. I was hoping someone had done it before, and could supply part numbers etc...
Update: new synchros, gaskets arrived today. I checked the old against
the new and the new stuff looks correct.
Assembly will be a few days from now since I'm still hopeful of getting a
secondhand replacement sleeve in good nick. R32 GTR owners, take heed :D
edit: I got my parts from North Shore Mitsubishi.
Call 02 9439 3099 and ask for Nissan Spares.
Regards,
Saliya
Edited by saliya
i was planning on doing something similar soon actually.
but i have 3 boxes to build one being from a gti-r
i'm sure 3rd gear is f**ked in the gtr box i have.
what was the cost in getting parts for the box?
Hi,
The cost is above; it was less than $400 for the 3 synchros + gaskets + oil seal.
Bearings are probably going to run me another $200 or so. This is all you should
need to recondition a box provided you haven't actually broken something.
If the gear is stuffed then you are up for big dollars (around $2k minimum for
genuine Nissan stuff).
This is because you need to replace the countershaft with the gears on it
(pretty sure it's one piece), then 1st-3rd on the output shaft,
1st-3rd sleeves/bearings/etc. Nasty.
At this point it's worthwhile investigating just buying a replacement box
(they seem to be around the $1k mark) or if you're doing the rebuild to
handle horsepower, investigating an OS Giken, PAR or PPG gear set.
PAR have 1st-3rd on the shelf, they quoted me roughly $4800 for me
to drop in a gearbox then pick it up with strengthened 1st-3rd (which
essentially gets you 1st-4th since 4th is direct drive).
OS is about $3k but I don't know exactly what you get for that money.
I haven't spoken to PPG since $5k is way out of my current budget,
and I understand that to go down the PPG path is more expensive again.
Regards,
Saliya
Guest Mashrock
oh my car is all up and running with the 34 gearbox in it.
i just have alot of shit around the house, thought i'd see if i could fix and move on.
but it appears now after some inspection that nissan will be f**king me up the ass to get parts
as there is no 3rd gear on either shafts at all. it looks pretty sweet.
i even giggled when my mate broke it one night.
Final costings:
2nd, 3rd, 4th synchros + gasket set from Nissan - under $400
R+R gearbox - $0 (self)
New thrust bearing - $50ish
New internal bearing set - $300ish (not $200, were unable to get from regular supplier)
Workshop labour to disassemble/check/reassemble box - $450
Total cost $1200. I had hoped to get out of this for $1000 or less;
and probably would have made it if I could have waited for cheaper
bearings or got trade on the synchros/gaskets.
Regards,
Saliya
Saliya, could you get me prices on stuff for my gb. It seems your Nissan dealer is a fair bit cheaper than mine.
I have the r33 series 1 box. I need a complete bearing set, but wouldnt mind a price on parts required to rebuild the whole box too (like complete syncro set, gaskets, and any other bearings/seals ive missed) Only thing i dont need is the gears themselves...
Your help would be much appreciated :unsure:
Edited by Bl4cK32
Saliya,
If you can - can you break this down a bit further..
You said - R+R - $0 - do you mean it cost you nothing to pull it down and put it back in.. not quite sure what you mean..
$450 - was that pulling it all apart, putting in new synchros & re-pressing the bearings??
Seems like you did alright..
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
