Hey everyone..
How beneficial are cold air intakes?
I'm thinking about putting one on my r32..
I've heard that cold air feeds are no good, but putting the actual pod where the side mount used to sit is better. Why is this?
I understand that there isnt a set amount of power increase i.e. "a gain of 20kw"
Cheers.
https://www.sau.com.au/forums/topic/117729-cold-air-intakes/
I'm not 100% sure of this, but:
I know that just a POD by it'self will make little power differnces as it may be sucking in hot air from the engine... If you simply partition it off however, I have heard that you will get very little airflow, to the pod so it may also not be of much help... so with that in mind, im assuming that placing the pod where the sidemount used to be, you would get the best of both worlds, cold air, and good flow...
Although I'd be a little worried about it getting wet :S
At least get a bit of pipe to your filter, fresh cold air will help. I did it to my car and noticed the difference. Apparently you need about 10hp gain to notice it. Cant tell you how much it really was, but for the little outlay, Id spend the money.
Fair enough.
I'm thinking about putting it where the sidemount use to go instead of getting a pipe to it. But if its not all that noticeable then i guess i wouldnt bother..
Ligneringsoul - i didnt actually mean 20kw, i just said that for example to illustrate a point.
i wouldnt like to put it where the side mount was due to driving it and collecting water just like my mates did, drivin along and up sucked a big puddle of water wasnt good for his car, so i have my k&n in a polished box so its sealed from all heat ( except on the side behind the headlight) and with the open hole from the stock intercooler pipe, i just got some flexible tubing from bunnings and made a air duct to the vent in the front bar, still can suck up a little water if it was a big enough puddle i guess, but no where near as bad as the filter basically on the ground... if u put the duct going up with a sealed box u will get ample amounts of air, ive stuck my hand over the hole when its been on the dyno and thats alot of air...
ben...
2BNVS, did your friends motor actually fail, from ingesting water?
Have always heard about the external pod will suck water and hydraulic the engine but have never actually seen or had personal evidence of it happening.
At least four of my friends have pods sitting out the bay, two of them with splash guards and two with nothing which have been running for a couple years without drama. Not to say it cant happen, I wouldnt do it, but I've never seen it happen.
When you think about it, it would have to be a good effort for enough water to get all the way to the engine.
Firstly, the filter itself would hold a lot of it, then it has to go through the intake pipe to the fast spinning turbo, which creates heat, then it has to get through all the fins of the cooler, which would grab a lot of it and finally around the rest of the piping and up to the engine.\
For infos sake, I have an import R31 and cant run a cold air feed without cutting things up which I dont want to do at present so I have a pod inside the bay which only gets an ambient feed from the factories airbox snorkel and lid hovering over it. Better than nothong I guess.
thats easy,yes it is benificial.As long as there is none to minimal hot air entering the cold air box.
The car feels lilke it stays in a useable power band longer.
I am currently thinking of insulating the outside of the stocko airbox.Ive allready gutted the lid and smoothed out all the plastic vanes.
One of my other steps could possibly involve a cold air feed from the foward facing vent in the bonnet straight into the top of the air box virtually eliminating all of the air being drawn from the snorkel.
One bad thing about this though is the fact that more dirt will fill the filter.
I came back from driving 30 mins the other night and felt the crossover pipe.it was pretty much stone cold.I was amazed...M2C..
Hey everyone..
Cheers.
They do make a difference especialy on hot days just make sure you have your pod partitioned off from the rest of the engine bay or else you are probably wasting your time
cheers
Edited by Munna1
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
