hey ive tried looking through the posts and i cant find wat im looking for. so i was wondering if u guys could help me out. i hav a 1990 r32 gtst and i was wondering how much boost i can run on the ceramic turbo. i only hav the standard fmic, boost controler and an impul computer.
thanx heaps guys
https://www.sau.com.au/forums/topic/117765-how-much-boost-is-safe/
  • Replies 55
Burnsie.
I know people who have run 15psi through there stock ceramic turbo's on rb20dets. One guy i know blew his up after about 20 thousand kays i think.
Another of my mates was running 14 through his and his car ran fine for well over 50 thoudand, iv now got that same turbo for my GTS.
Some people are lucky i guess
tell me to shut up if im wrong but theres heaps of posts iv read in the past saying that stock boost is 6.8psi for the rb20det.
all my mates 32 gts't's read 7psi on there guages when they were stock.
may mate ran 8psi after his 3inch zorst was installed.
Edited by blackprincegts
hold up you ARE using an aftermarket boost gauge right as opposed to the stock one thats on your dash (which isnt in psi! it reads in 1000mhg or something, 7 being about 14 psi)? 99.9% of topics say 10 psi is stock, and 12 psi is recommend (my boost gauge read at about 10.3 psi)
Edited by r32 gts-turbo
yeah im using aftermarket boost gauge but the one on my dash only goes to 7psi so thats y i thought 7psi must be stock and ive been told by heaps of ppl that they come out with 7psi stock but im prob wrong.
Edited by burnsie
hmmmm, .55 bar is 7.9750000000000005 psi if u wana be exact :yes:
The stock boost gauge isnt in psi! its in some other reading, have a close look at it and itll say something like X1000mhg. At 7 on the gauge it would add up to about 14 psi, but as these things only boost 10 psi stock its rather innacurate (under full throttle mine jumps all the way to 7 which would seem to imply i was running 14 psi stock)
I thought the same thing.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
