What happens if im test driving n the screw falls off in the middle of it??
hehehe
Do u start off with the Screw all the way Out??? i can't remember where it was Pre_Set when i first got it.. so yeh
Cheers
Edited by Black_CSR
  • Replies 55
wouldn't have to change the bov, unless it starts leaking when you get on boost. the stock bov is designed to leak at all times. it has a hole in it to do so. this leaking also helps it hold higher boost as the leaking air pushes down on the top of it to keep it closed. i blocked mine up and it started leaking boost so i unblocked and it doesn't spike. but going to an aftermarket bov will stop it leaking any boost and make it spool up a touch quicker. (its like trying to fill a bucket with a cup with a hole in it. plug up the hole and you will fill the bucket quicker).
you would need an aftermarket ecu to get rid of boost cut. and remember that 14psi on a high flow will give more power than 14psi on stock turbo.
Edited by mad082
Thanks mate, exactly what I needed to know.
Well at the moment.. i'm running 12 Psi.. n i'm not getting any Fuel Cut for some reason.. so i'm not sure if i have a Stock Ecu n it has a Rev Limiter on it as well...
I remember when i did my first Test Run when the Boost Controller started working.. it went upto 15 psi.. but didn't cut out.. but i didn't give it stick till redline.. just suprised it went up that high.. n did Pop when i changed gear..
What if i keep it on 12.. n get FMIC.. will that b ok???
Oh yeh Evil_weevil.. u going to Antilag Cruise this weekend??? if u r u could sort my boost problem when i c ya hehe
-SeSaR
Edited by Black_CSR
depends on mods. it is based off air flow, not boost pressure. i was running 13psi with stock dump and cat with not boost cut. the day i put on the dump and cat boost cut was kicking in at 1/4 throttle so i had to wind the boost down.
So Mad082..
As long as I don't get any Boost Cut... it should b ok to Run??
I have a HKS Filter n Zorst 2 1/2 wif Cat n High Flow Muffler.. was driving tonite n was cruising along in the freeway in 5th doing about 90... so i put it in 3rd n give it some stick n c how it go..
It went Hard Alright... but the Boost went upto 13-14 psi.. i'm guessin the Cold night gave it extra PSI
didn't cut out though.. kept going hard.. then had a played around wif this SS... didn't Cut out... Caned it up 2 about 4th then slowed down was worried it mite POP..
-SeSaR
Edited by Black_CSR
yeah should be cool. just have to watch out that it doesn't do it when the engine is cold, but you shouldn't be driving it hard when the engine is still cold. when i have the boost at about 13psi i get boost cut until the pipes heat up. the engine can come nearly up to temp and if i give it a quick boot in 3rd it will start to rev up then cut. it will only do it once or twice, then the cooler and piping comes up to temp and it won't do it again.
it only did it in the morning on the way to work... and on the way to the dyno run, so i had to wind the boost down which i was a bit annoyed about cause i took it for a spin the night before to see if it was going to do it and it didn't.
Sounds Good.. well i put it Back on the way it was before.. which is connect it to the Stock Selonoid.. in which it's suppose to Run Stock Boost n gave it a quick run n it went only up 6.5psi n won't get any higher.. where it used 2 b 8psi.. so that kinda annoyed me..
but anyway i'll put it back on n c how it runs for the Cruise on Sat Nite..
SeSaR
This is getting f*kkin rediculous
You know what is fcukin ridiculous, people like you who think everyone knows how to use the search function from the word go. fcukin ridiculous. Were you born a dickhead or do you work really hard at being one. Grow up Kris.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
