I am not sure if this is the right place for this, but I could not see a specific section for pics of our cars, so if it is in the wrong section, I apologise.
Anyway, here is a couple of pics of my newly acquired black R33 Series II GTS-T. It is basically stock except exhaust system and HKS pod filter. It also has 17" mags, lowered, and has Cusco front and rear strut braces.
She looks to be in pretty good nick, only 72000 on the clock (whether that is genuine I am not sure), the interior is immaculate.
Feel free to make any comments (good or bad) you like, this is my first Skyline so I am interested to see what other people think.
https://www.sau.com.au/forums/topic/117805-my-96-r33-gts-t/
  • 3 weeks later...
Nah, I got it from a car yard on Parramatta Rd. I won't mention who because I don't have too many nice things to say about them.
I also discovered my car has a turbo back exhaust - 3" from turbo to cat, Catco cat, 3.5" cat back into HKS cannon. It also has braided brake lines.
https://www.sau.com.au/forums/topic/117805-my-96-r33-gts-t/#findComment-2260574
dont know what problems you're having with the car quinny, but as i said before, ive got a black s2, and yours just looks fantastic. I'm very tempted to remove the S badge on the bonnet after seeing yours...
Then again the paint job on yours looks a lot better than mine so that probably helps a lot :devil:
https://www.sau.com.au/forums/topic/117805-my-96-r33-gts-t/#findComment-2260799
Your pics don't show a badge?
Mine is there, I had to buy it brand new ($60!!) because the previous owner stuck a Silvia badge on there... with superglue or something. It didn't look pretty when it was removed.
https://www.sau.com.au/forums/topic/117805-my-96-r33-gts-t/#findComment-2260953
Then again the paint job on yours looks a lot better than mine so that probably helps a lot :whistling:
Not really having any problems with the car, had to replace the clutch after only having it for 2 weeks, which was a mission. Took us half a day to get the car apart and change the clutch, about 2 days to get the box back in, and about 2 hours to bolt everything else back up.
The only other problems I have is that side skirts have come unstuck, which looks a little crap, but that should be pretty easy to fix, and also my passenger side headlight keeps getting water in it.
The badge was not on the car when I bought it, so I take it the previous owner took it off. I probably would have removed it anyway.
Edited by Quinny
https://www.sau.com.au/forums/topic/117805-my-96-r33-gts-t/#findComment-2261975
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
