  • Replies 90
Posted Images
is it on the motor or in the engine bay..what does it look like?
It's in the engine bay.
http://img.photobucket.com/albums/v218/McC...BypassSmall.jpg
Bottom right of picture.
Hi
i'm after the driver seat only.
what's the best you can do? :)
$100 for drivers seat.Or it goes in my new R33 and u can buy the drivers seat out of it for $50 with some marks..may be cig burn marks. Damn smokers!!!
