T.V show The Contender has made me want to watch this badly.
Just your thoughts on the fight between Green vs. Mundine.
Who do want to win, who are you going for?
Where might some of you be watching this fight from?
Has anyone put big bucks up for the win?
Edited by Justin O
https://www.sau.com.au/forums/topic/118114-green-vs-mundine/
  • Replies 88
i wouldn't worry too much, he doesn't seem to mind offending every other person on the planet! :D
very talented man, but he needs to be put in his place
oh thankyou, finally someone who thinks the same as i do...
haha im ron burgandy?
I LOVE LAMP....I DONT KNOW WHAT WE'RE YELLING ABOUT!!! HEHE
dont worry, i thought i was the only 1 who wants green to destroy him....then i posted it in the wasteland, and i had so much support! lol
go green
As someone who has watched every one of both fighters fights (I'm a bit of a boxing fan) I can tell you this is a very hard fight to predict. Neither fighter has fought anyone like the other person before as far as styles go.
3 years ago I think this fight would have been easy to predict. Danny Green easily. But with a bad run of injuries and a few other problems I feel currently you'd have to tip the scales towards Mundine winning this fight.
And sure the guy is a dick but he can fight and this is a boxing match not a personality contest.
i dont really follow this boxing... aussie boxing doesnt do it for me. Who have these guys actually faught that is of any reasonable skill? Thats not a sarcastic question either i just dont know.
mundine is good but hes not exactly a sensational boxer that will make a big name for himself globally.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
